There could be a few possible reasons for the grinding noise in your Fisher and Paykel front loader washing machine. Here are a few things to check:
- Check the drum paddles: If the drum paddles are worn or broken, they can create a grinding noise during the wash cycle. Check to see if any of the paddles are loose or damaged.
- Check the drum bearings: The drum bearings are responsible for supporting the drum and allowing it to spin smoothly. If they are worn or damaged, they can cause a grinding noise. To check the bearings, try spinning the drum by hand. If it makes a grinding noise or feels rough, the bearings may need to be replaced.
- Check the drive belt: If the drive belt is loose or worn, it can cause a grinding noise. Check the belt for any signs of wear or damage, and make sure it is properly tensioned.
- Check the motor: A faulty motor can sometimes cause a grinding noise. If you suspect the motor is the problem, it's best to call a professional for assistance.
If none of these solutions fix the problem, it's best to call a professional to diagnose and repair the issue.
