Have you used the vMeyecloud app for video monitoring it is available for download for pc here https://www.myfirstmac.com/vmeyecloud-pc-windows-7810-mac-computer-free-download/
What model Kodak 8.0 megapixel camera? The M1063 is a 10 megapixel model.
Some Kodak cameras can charge the battery when you connect the camera to a power source. Some Kodak cameras come with a separate battery charger. Some Kodak cameras use disposable batteries. Without knowing the model of your camera I can't tell you how to charge your camera.
SOURCE: kodak cx7430 digital camera will not charge
Try taking the rechargeable batteries out of the camera for a few seconds and then put them back in.
SOURCE: I have a Kodak 8.1megapixal digital camera won't charge
Fixing your problem could be as simple as cleaning the battery contacts
in the camera, or the solution could be a lot more complex and
expensive. Here's a link to the Kodak Help Center - it provides a
simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
SOURCE: Junk Kodak Z14854IS digital camera?
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
SOURCE: Kodak EasyShare M340 Digital Camera
Maybe, the batteries need to be changed to new ones.
Try to use Li ion batteries as recommended by Kodak.
