SOURCE: LG privilege WD-3243RHD User Manual
Find out where in your area it was sold and phone or ask salesman for Manuel or instructions they will be glad to help.
SOURCE: LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
SOURCE: I have an LG Washer and Dryer Combo #WM3431HS. It
this dryer don't used external vent , please read manual, this is a vapor dryer
SOURCE: my lg washer and dryer wm3431hs isn't draining. I
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...
Daniel
