SOURCE: printer
Paul,
did you had a paperjam the days before?
The encoder strip which gives the print head the position is out of position. It has to be fixed into the ph.
Read my post here (same issue and same procedure):
http://www.fixya.com/support/t272288-unable_print
SOURCE: unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
SOURCE: [HELP] MY BROTHER MF-210C "UNABLE TO INIT"
Dear Guru,
I have a same problem" UNABLE TO INIT " but my printer DCP 110.
Please can help me.Thanks
SOURCE: Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
SOURCE: machine error 48 or init unable 48
There are several issues that pertain to this code, including a service update. If your printer is still under warranty – visit your local ASC, find one here, this issue is covered! First off, the Service Update, the encoder strip needs to be cleaned with a lint free cloth. The encoder strip is responsible for relaying the position of the print head to the main pcb. If the encoder strip gets dirty, many different problems can occur. The encoder strip is exposed, which allows grease, paper dust, finger prints, ink, etc. to get onto the encoder strip. (The white strip when you open the scanner cover)
If the machine still errors, the encoder strip needs to be replaced – Part Number LS4467001
If the machine still errors, replace the carriage PCB assembly – Part Number LS6543001
If the machine still errors, replace the Printhead – Part Number LK3211001
If the machine still errors, replace the Main PCB assembly – Part Number LT0284011
THANK YOU FOR USING FIXYA! – DON’T FORGET TO RATE OUR SERVICE!
