SOURCE: KM-2530 with C0050 error code ?
it's the the expansion card on the main board in the middle, has a yellow circular cmos battery. Either its faulty or popped out during moving the machine. if faulty, replace.
SOURCE: auto paper feed jamming
clean the rollers with alcohol. this will renew the rubber and clear up the problem
SOURCE: Kyocera Mita KM-2530 Laser Printer will only print the first page not the rest.
Try changing print driver and switch emulation to kpdl auto if not already there. If this doesn't work go to properties on driver under font and switch to bit map. Don't do this step unles yo have to it really slows down your printer.
Log into your pc as admin and under the driver properties change from kpdl to pcl5
Its a combo of a problem with adobe reader and the KPDL driver
Are you using an after market toner? Sometimes the non Kyocera toner causes light copies?
