Firmware
SOURCE: Need to change fax number programmed in Ricoh, afico 3025
Press the User tools/counter button;
Touch the Facsimile features icon on the touch panel;
select Gen. settings/Adjust tab;
touch Program fax information;
touch Own fax number;
touch For G3-1, then enter your fax number from the blue numeric
keypad then touch OK.
Touch Exit, then press User tools/counter button to go to Standby mode.
SOURCE: Does not print from Mac OX 10.5 Leopard
from a mac, you need to have a post script print option installed, the system only came with pcl
http://www.websitetoolbox.com/mb/copierquestions
SOURCE: Ricoh aficio 3025 says PLEASE WAIT and stays in this mode forever
Check for SC codes.
Check the following probabilities;
Good luck and please rate me, thanks.
SOURCE: i want download the engine firmware ricoh aficio
When I can download the firmware cicu / bcu 8.1 by ricoh aficio 1085?
SOURCE: i have a ricoh Aficio 3025 all in one, it is now
its temp. or fixing error. try to clear it in service mode.
yellow 197 red when it says SERVICE MODE turn off and on machine, if it does not help you need to call service to replace thermistor, or lamp, or rise temp. ,or ...
