Hello, Lower Cable winder broke on my Dyson DC41 and i got a replacement part from Dyson. I need help replacing it. I took the hose off but can't figure out how to take the old part out. Could not find anything online. Any help would be appreciated.
Hi Mani, it's Jack at Dyson.
DC41's lower cable winder is attached to the hose assembly, and if the cable winder has broken you would need a replacement hose assembly. It's likely your DC41 would still be within our 5-year guarantee period, so it would be worth contacting us directly so we can order this for you.
When you have a moment, please give us a call on 0800 298 0298 (UK) or 1-866-693-9766 (US) to speak with our experts.
SOURCE: beater bar belt needs replacedon a dyson DC14 animal
Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
Its in the instruction book
SOURCE: dyson suction loss
make sure the filters in the bottom are clean, then remove the canister and you will need to clean it thouroughly, pay close attention to the upper section inside where the "cones" come togetheri have read that they are prone to clog up here and lose suction, google dyson suction loss or how to clean a dyson ect...pay attention to getting the rod that releases the bottom to dump back in the correct place or it will not work right. a few write ups tell about this!
SOURCE: dyson dc05stduk vacum cleaner need to replace power cable
Hi
Try this site does manuals on Dc05 repairs.
http://dysonmanuals.llc.nu
SOURCE: Hello, How can I clean the
HI there,
By Lower filter i am going to assume you mean the one below the clear plastic dust bin. The machine you have described has a thick hepa filter (probably with a purple plastic rim) and unfortunately they cannot be effectively cleaned. If you are keen to try then I would suggest using an air compressor blowing from the top to the bottom.
What I would really suggest you do though is throw it out and replace the hepa filter with a new one. If you are in Australia I would try Vacuumspot or Nelson Vacuums.
SOURCE: Lower filter repair to eliminate excess noise
I'm sorry to hear your DC18 is making an unusual noise. Please note, the filter located beneath the clear bin is designed to last the lifetime of the machine, and does not need to be maintained or replaced. Attempting to clean this filter is likely to cause damage, so we'd strongly advise against this.
Although I note you've already cleaned the filter located inside the cyclone pack, you might want to take a look at the video below to check you've done so as recommended. In normal use, this should be done at least once every 3 months. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely somewhere warm before replacing it.
You may also want to run through the troubleshooting steps shown in our Support guide to make sure there are no obstructions you may have missed:
http://www.dyson.co.uk/support/dc18/dc18-all-floors/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
If your machine continues to make an unusual noise, I'd encourage you to get in touch with us directly, as we'd appreciate the opportunity to provide further assistance. You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com/
I was able to replace the lower cable winder really easily. Take the hose off the DC41 and simply push back and pull/push up the lower cable winder out. It should pop out easy. Put the new one back in and put the hose back.
