I put a new compressor in an pulled the vac on it an my freon goes in the high side so now im looking for the exspanion valve an cant find it
SOURCE: I have a 2003 vw jetta 1.8t. The a/c system is
just start adding freon and the compressor will kick on when enough is added and don't forget to add oil and turn air on max
SOURCE: air condition not cooling
If this is a heat pump it sounds like the reversing valve is stuck in the heat mode, replacing it requires opening the sealed system, which needs to be done by a licensed ac repairman.
SOURCE: 24ABR348A0031010 compressor starts then stops.
Hello RR Hard start can't hurt BUT dosen't sound like the problem.Do you have a scroll compressor?They don't need a kit.Does it start every time?It could be short cycling on LOW PRESSURE SWITCH.If the unit is (pumping down) during the run time you have a restriction in the system.Make sure the service valves are open ,do you have a filter dryer colgging up or a bad TXV valve also could cause short run times.20-30 PSI the switch cuts out.
SOURCE: Hello, I have a Calvinator A410 unit that I am
There should be a name plate with the model and serial # which will tell you what the factory charge is for the unit plus 15 to 25 feet of line set. If you weight in the charge you should be pretty close...... In AC mode you should run around 125# suction and about 265 head pressure with 70 degree ambient F. If you have the right charge in the heat pump and you are still running 25# suction pressure in the Air Condition mode then you have a restriction filter drier or TXV locking up..... Did you replace the filter drier when you fixed the leak was the leak on the suction side if so then you definitely need to change the filter drier.
SOURCE: temp off air coming out
Hello, what is your high side pressure? A bad compressor will show abnormally high low side pressure with abnormally low high side pressure. That 45 low side pressure is low And superheat high. If you high side pressure is normal toma little above normal but the low side remains low you have a restriction in the system, that might be why it's not taking in tne freon. Let me know you high side pressure
Frost on the low side line means the system is overcharged (too much freon). Look on the tag insided the fridge and it will tell you how much freon it holds. Usually 4.25-5.50 ounces on average. The loud noise sounds like you have air in the system. I would evacuate, from the high side while running, and let it run empty for 5-10 minutes. Then while running put the valve core back in the high side. Then unplug the fridge and charge with proper amount of freon thru the high side. Wait about 5-10 minutes and plug back in. Normal low side pressure should be 0-3 psi. This is a good indicator of the proper amount of freon in a good working system.
