My camera hasn't been working for a while now. I've used multiple new batteries and have cleaned the compartment many times. I'm about to give up! Any advice of what i should do?
SOURCE: my digital camera will not turn on
My problem is now fixed! I put in a fresh set of recently purchased non-rechargeable batteries into the camera.
I was out-of-state visiting my Dad and taking many photos of his things. I ended up replacing my batteries with some he had around the house just prior to the first instance of camera's problem.
[I do not know the age of Dad's batteries!]
I went to Kodak's website [link] www.kodak.com/global/en/service/products/ekn027989.jhtml?pq-path=3906/1931
On this page is a heading "Troubleshoot And Repair," and I followed the link - Step-by-Step Solutions & Repair .
Perhaps this would help others who posted....
Marcia
Solved Issue with Kodak EasyShare CX7430 Digital Camera
SOURCE: My Kodak EasyShare DX4530 camera dock not charging batteries.
There was an issue with the 4000 series and the NiCd batteries I remember that had to do with the contacts in the camera. The charging circuit is in the camera so you have to make sure that the battery contacts are clean, both on the battery and in the camera.
SOURCE: Kodak Z700 not firing up
Same problem as described above. Fresh batteries, turn it on, see the Kodak screen for a second, then it just turns off. I found that if you swith it to the favorites icon (the only one below the Off position) it stays on and I can review photos. But no taking new photos! Help!!!
SOURCE: My Kodak EASYSHARE M1063 camera won't turn on
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
SOURCE: kodak easyshare Z740 battery problem
I may be able to help with your Kodak EasyShare Z740 that turns itself
off.
Try these steps to fix your camera.
I
hope that helps.
_____________________________________________
Turns Off Fix
Manual Download
