When cc is on, black lines appear on screen.
SOURCE: 3 colored lines
Is the 3 colored lines always in the same location? Top to Bottom or Side to Side?
The plasma panel is bad if it is from Top to bottom and the 3 colored lines are always in the same location.
The Z Sus, Y Sus and Y buffers are suspect is the lines are not always in one location and it is from side to side.
Repair cost is about half of your purchase price if the plasma is bad. I hope your unit is under warranty. Best Regards
SOURCE: Colored Lines
Hi
You have defective vertical output IC. and 1.5ohms resistor. this two parts need to replace a new one.
No other...
Thanks!
SOURCE: WAS WATCHING TV AND IT WENT OUT
check ur antenna connection....to ur tv,,,,,also check antenna and cable.....if problem keeps on going go in touch LG customer service
good luck
SOURCE: screen got black lines across it
I strongly disagree with expert given info.
LG 42LC2D is LCD tv that does not have all those circuit boards that expert is talking about.
Problem sounds with lcd panel that got black lines, lcd panel will be replaced to fix he tv but it would cost you 80% of new tv price.
