You can try https://wikierror.org/windows/0x800f0922/
Hi there. Firstly... make your mom a cup of tea . You know how to calm her down . Then take on this task . It looks like a impossible task , but just follow the instructions . You can do this:
Install the Windows 8.1 Update (KB 2919355)
Code 0x800F0923
This error might mean that a driver or other software on your PC isn't compatible with the update. For info about how to fix this problem, contact Microsoft support.
Code 0x800F0922
This error might mean that your PC couldn't connect to the Windows Update servers. If you're using a VPN connection to connect to a work network, disconnect from the network and turn off the VPN software (if applicable) and then try to install the update again.
The error could also mean there isn't enough free space in the System Reserved partition. You might be able to fix this problem by using third-party software to increase the size of the System Reserved partition.
Error: We couldn't complete the updates. Undoing changes. Don't turn off your computer.
Error: Failure configuring Windows Updates. Reverting changes.
These are generic errors that might appear any time a Windows update fails. You'll need to determine the specific error code to investigate how to best resolve this problem
You can find the error code for the failed update by viewing your update history. Look for KB 2919355 in the list, note the error code, and then contact Microsoft support.
To view your update history:
Error: The update is not applicable to your computer.
This error might mean that your PC doesn't have the required update KB 2919442 installed. Check to make sure that all important updates, including KB 2919442, are installed on your PC. If all updates are installed, you might need to refresh your PC.
To refresh you PC:
SOURCE: hot shots golf out of bounds troubles
This happened to me as well. The first time, my PS3 seemed to hang during the second update. The next time, I quit the update because I thought the system was stuck in an infinite loop. Turns out that it isn't.
Start from the beginning by deleting the game data file from the PS3 hard drive. Boot up HSG:OOB and wait for it to install. This takes a while, as I think it is something like a 5GB install. When it is finished, go into the game and select the Online option.
You'll see the "Checking version" message followed by a couple of status bars. Depending upon your connection, the update can take anywhere from 30 minutes to over an hour. Just walk away and come back to it. When it is finished, you'll be told to press the PS button to quit and then restart the game.
Once back on the main screen, you should see a version # that wasn't there before, on the right side of the screen. You might want to write this number down.
Go back into the Online option. Once again, you'll see a "Checking version" message followed by a couple of status bars. It looks the same as the last update, so you might think this is an error. It isn't. Apparently, rather than updating once to the latest version, the game is going through a series of updates (2 or 3 of them). It's like taking Windows 95, updating it to Windows 98, then updating it to Windows ME, and finally updating it to Windows XP.
Wait for the update process another time or two. For me, each subsequent update took less time. Something like 20-30 minutes for the last one. When you are asked to quit and restart the game, check the version on the main screen. It should be different than what you wrote down after the first update. For me, my updates ended with ver. 090311201. Finally, I was able to select online and it didn't check the version but asked for my login info.
Whenever they update the game, I'm sure we'll have to download the update once again...but hopefully each new update will be minor. But those people who purchase the game brand new will end up going through even more updates with each passing year.
SOURCE: Card malfunctioning while playing full-screen games
Try disabling the screen saver and see what happens.
SOURCE: Try to play pogo games
Please follow these instrucions to clean up your Java installation.
There is a program called JavaRa that will remove all the old Java versions from your computer. Go here to read about it, then it is a free download from here.
Extract the .zip file to your desktop or create a My Programs\JavaRa folder and send it there. Close your browser and run the JavaRa.exe file and choose 'remove older versions.' When done, it will show you a log file of the Java versions found on your computer and removed. Close that.
Now open JavaRa again if it is not still there behind the log file. Choose "Search for updates" and then "Update using SunJava's website" A browser window should open at the Java home page. (http://java.sun.com/javase/downloads/index.jsp)
Scroll down to the Java SE Runtime Environment (JRE) and choose download. Choose windows from the options, check the license, then choose offline or online installation and click the orange download bar.
Save the file to your desktop or folder, then close your browsers, and click on the file to install Java.
This will give you the most recent version of Java available, which should work seamlessly with Pogo applications.
To check, go to this page and reactivate your Pogo account. Then try to play games.
If your account is properly activated, and you're still having problems, please see this page.
If you want help with these last settings, write back and let us know the exact error message you get from Pogo, and we'll help you to adjust your browser settings to get you in.
I don't see any reason why you shouldn't be able to play with Windows xp. I'm sure you can get it sorted out...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: I purchased a Sylvania Netbook
This is a very limited machine, the only thing that you can do with it is read Emails and go to the internet and look at some you tube. There is not enough memory to support detail such as facebook. The browser I.E. for CE is also very limited and some sites will not down load to it as it is recognized as a outdated program. Since there is no way to download games and play them you are out of luck.
SOURCE: when I go to play Facebook games I get a blank white screen
hmm i suspect that your adobe flash is not current
try this link and get newest version and then let me know results
