Question about Microsoft Excel for PC
What is the easiest way to link several formulas from seperate worksheets?
Trying to link several formulas from multiple worksheets into one overall workbook
  • Scott Jul 17, 2014
    I'm sure I can answer your question, but I need you to describe what you're trying to achieve in more detail.
  • 156 Answers
Pen both the sheets in the same window as:-
1. View Tab-->New Window --> Arrange All --> tiled
2. Open first sheet in first window and second in second window
3. now create formula simply by clicking in corresponding sheets and selecting cells.
Alternatively you can use following format of addressing:-
1. SheetName!CellAddress (Same Workbook)
2. [WorkbookName]SheetName!CellAddress (Different Workbooks)
For more clarification please mail on ali_zulfikar@yahoo.com with screenshots.
Posted on Sep 16, 2017
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 26 Answers
SOURCE: MS EXCEL 2000 corrupted workbooks/worksheets
it sounds like you are going over the limits of the program these are the specs. I would recommend dividing up the data if you can. or moving it to a database that can act like excel and hold more data.
Posted on Apr 29, 2008
Anonymous
SOURCE: linking multiple formulas
i want all excel formula
Posted on Dec 30, 2008
How to calculate the percentage using the excel
Hide All
Percentages are calculated by using the following equation:
amount/total = percentage
Where percentage is in decimal format.
What do you want to do?
Calculate the amount if you know the total and percentage For example, if you purchase a computer for $800 and there is an 8.9% sales tax, how much do you have to pay for the sales tax? In this example, you want to find 8.9% of 800.
Example The example may be easier to understand if you copy it to a blank worksheet.
  1. Create a blank workbook or worksheet.
  2. Select the example in the Help topic. Note Do not select the row or column headers.
    Selecting an example from Help
  3. Press CTRL+C.
  4. In the worksheet, select cell A1, and press CTRL+V.
  5. To switch between viewing the results and viewing the formulas that return the results, press CTRL+` (grave accent), or on the Formulas tab, in the Formula Auditing group, click the Show Formulas button.
1 2 A B Purchase price Sales tax (in decimal form) 800 0.089 Formula Description (Result) =A2*B2 Multiplies 800 by 0.089 to find the amount of sales tax to pay ($71.20) Note To convert a number in percentage format to a decimal, divide it by 100. For example, the sales tax in this example (8.9) divided by 100 is .089.
Calculate the percentage if you know the total and amount For example, if you score 42 points correctly out of 50, what is the percentage of correct answers?
  3. Press CTRL+C.
Simple way Amount/Total*100
Apr 30, 2011 | Computers & Internet
My MS Excel vlookup function ASCII type table contains both upper case and lower case letters, characters like ( and % or *, and numbers. It seems to return the numerical equivalent of upper case letters...
Correct a #N/A error blueup_clv.gifShow All bluedrop_clv.gifHide All This error occurs when a value is not available to a function or formula.
  1. Optionally, click the cell that displays the error, click the button that appears ooui1_za06043871.gif, and then click Show Calculation Steps if it appears.
  2. Review the following possible causes and solutions. blueup_clv.gifMissing data, and #N/A or NA() has been entered in its place
    Replace #N/A with new data.
    Note You can enter #N/A in those cells where data is not yet available. Formulas that refer to those cells will then return #N/A instead of attempting to calculate a value.
    blueup_clv.gifGiving an inappropriate value for the lookup_value argument in the HLOOKUP, LOOKUP, MATCH, or VLOOKUP worksheet function
    Make sure that the lookup_value argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) is the correct type of value — for example, a value or a cell reference, but not a range reference. blueup_clv.gifUsing the VLOOKUP, HLOOKUP, or MATCH worksheet function to locate a value in an unsorted table
    By default, functions that look up information in tables must be sorted in ascending order. However, the VLOOKUP and HLOOKUP worksheet functions contain a range_lookup argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) that instructs the function to find an exact match even if the table is not sorted. To find an exact match, set the range_lookup argument to FALSE. The MATCH worksheet function contains a match_type argument that specifies the order the list must be sorted in to find a match. If the function cannot find a match, try changing the match_type argument. To find an exact match, set the match_type argument to 0.
    blueup_clv.gifUsing an argument in an array formula that is not the same number of rows or columns as the range that contains the array formula
    If the array formula (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) has been entered into multiple cells, make sure that the ranges referenced by the formula have the same number of rows and columns, or enter the array formula into fewer cells. For example, if the array formula has been entered into a range 15 rows high (C1:C15) and the formula refers to a range 10 rows high (A1:A10), the range C11:C15 will display #N/A. To correct this error, enter the formula into a smaller range (for example, C1:C10), or change the range to which the formula refers to the same number of rows (for example, A1:A15).
    blueup_clv.gifOmitting one or more required arguments from a built-in or custom worksheet function
    Enter all arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function.
    blueup_clv.gifUsing a custom worksheet function that is not available
    Make sure that the workbook that contains the worksheet function is open and the function is working properly.
    blueup_clv.gifRunning a macro that enters a function that returns #N/A
    Make sure that the arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function are correct and in the correct position.
Oct 31, 2008 | Computers & Internet
Excel 2007
  1. Select all cells (either press Ctrl+A or click on the small upper left square on the edge of the worksheet)
  2. In the menu bar, go to Format - Cells
  3. In the popup menu that opens, click on the Protection tab (it should be the last one on the menu)
  4. Deselect the small box tagged Locked
  5. Click on OK. Now all your cells can be overwritten, regardless the protection status of the worksheet.
  6. Select only the cells containing formulas that you want to hide (If you need to perform multiple selection, you can press and hold down the Ctrl key, while clicking on each cell you want to select)
  7. In the menu bar, go to Format - Cells
  8. In the popup menu that opens, click on the Protection tab
  9. Tick the small box tagged Hidden and the Locked box as well. If you don’t tick the Locked box, other users of your worksheet would be able to overwrite the formula cells, without even knowing that they contain formulas (as they become invisible following this operation).
  10. Click on OK
  11. In the menu bar, go to Tools - Protection - Protect Sheet
  12. If you want, you can input a password for unlocking the worksheet. This will prevent others from unlocking it. If you don’t want to do that, leave the password field blank and press OK.
  13. Now click on one of your cells containing formulas and look at the formula bar. It should be empty, although the formula is still there. The cell would remain locked, but it would be automatically updated when changing the content of its precedents relating to the contained formula.
Jun 25, 2009 | Computers & Internet
Using sumifs formula accross multiple sheets
Here is the syntax: =SUMIF(Sheet2!A1:A3,"> 1", Sheet2!B1:B3)
This says if the cells A1 through A3 in worksheet "Sheet2" are greater than 1 then return the values from worksheet "Sheet2" cells B1 through B3.
Change the worksheet name Sheet2 to your worksheet name and change the cell references to the ones you need.
Apr 17, 2009 | Computers & Internet
Excel Spreadsheet
It could have a virus or simply too much data in it or too much data linked to it. Try doing a copy of the whole spreadsheet, and then paste the data into a new spreadsheet. If it doesn't contain too many different formulas, try pasting only the values, and then replace the formulas manually. You might also try just deleting the links, if there are any. If this doesn't solve it, reply to this thread and let us know.
Hope this will FixYa!!!
Sep 30, 2008 | Microsoft Excel for PC
Disable formulas with in a work sheet of Microsoft exl
  1. Select the cells with the formulas you want to disable.
  2. You can now either hide the formula by pressing CTRL and ` at the same time, or you can delete the formula by pressing the delet key on your keyboard.
Here's an easy way to select multiple formulas:
  1. Do one of the following:
  2. On the Edit menu, click Go To.
  3. Click Special.
  4. Click Formulas, and then select the check box next to the type of data you want to select.
Jul 23, 2008 | Microsoft Computers & Internet
Version Tracking in a workbook
Hi blackhand18,
This might be different on your version of excel but try this
=INFO("release")
Jun 04, 2008 | Excel (SS8SATAS5128400R)
Unsure of correct formula
You can add a reference from the worksheet 1 to all other worksheets
Is it OK?
Mar 08, 2008 | Microsoft Excel for PC
Exel 2003
You can refer to cells that are on other worksheets by perpending the name of the worksheet followed by an exclamation point (!) to the cell reference. In the following example, the AVERAGE worksheet function calculates the average value for the range C1:C10 on the worksheet named Marketing in the same workbook.
default.aspx?assetid=za010939481033 Refers to the worksheet named Marketing default.aspx?assetid=za010939491033 Refers to the range of cells between C1 and C10, inclusively
  1. Click the cell in which you want to enter the formula.
  2. In the formula bar (formula bar: A bar at the top of the Excel window that you use to enter or edit values or formulas in cells or charts. Displays the constant value or formula stored in the active cell.) default.aspx?assetid=za060515351033, type = (equal sign).
  3. Click the tab for the worksheet to be referenced.
  4. Select the cell or range of cells to be referenced.
Jan 01, 2008 | Microsoft Office Standard for PC
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
149 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
