Roland Boss DR 880 Dr Rhythm Drum Machine Logo
A
Anonymous Posted on Jul 16, 2014
No guitar sound output - Roland Boss DR 880 Dr Rhythm Drum Machine
2answers
Fishman LBX-001 2006 model. I'm having an issue with my guitar amp. It does not get any sound from an acoustic guitar, I tested my guitar in another amp and it works well. I plug an electric guitar into my...
I am no expert about such things but the electric guitar pickups work with steel strings, wouldn't work if the strings weren't steel - the pickup is a coil of wire and the vibration of the steel string generates an output in the coil the amplifier can work with.
The pickups of the acoustic guitar are presumably glorified microphones that would usually work in a similar fashion to the above, by generating an output but if they are active devices they will need a power supply in order to generate an output, something a standard amplifier input will not provide.
An active device either needs an independent power supply to make the device work like a radio needs a battery or the device will create the output by varying the current flow of the voltage applied across it.
How to play my acoustic guitar on my my jbl avr134 home sound system it does have a amplifier I want the steps for it plzz
An acoustic guitar, unless it is an electric type, will need to be played near a microphone in order to provide a signal for the sound system and the microphone or the guitar will have to be connected to a compatible amplifier input.
Impedance matching is not so important unless high quality is required but matching the sensitivity or gain of the input to the output of the source is important for optimum performance.
A moving coil microphone has an output of just a few millivolts and a crystal microphone can produce an output of around one volt.
Aug 10, 2015 • JBL Music
My ltd deluxe ec-1000(vintage black) is not producing any distortion on my Marshall mg100hdfx. this is the first time i have had an active pickup guitar, i put a new 9v battery in it but still no change in...
Distortion is not produced in the guitar. Distortion is generated in the amp by circuitry that increses the gain until the waveforms "flat top". This creates higher harmonics and a buzzy sound. If you are getting a very low output from your guitar it is possible that you don't have enough output to get the distortion in the amp to work. Other settings in the guitar add harmonics by mixing more than one pickup. This is not ditortion but adding these harmonics changes the sound immensly.
LOOK AT THIS SITE AND FIND A SCHEMATIC THAT MATCHES THE RESOURCES OF YOUR GUITAR... You might be able to figure where the wire goes... It may be a ground.
http://www.guitarelectronics.com/c=D65u46R1H9tko6CKpPLsjBhiJ/category/wiring_resources_guitar_wiring_diagrams/
I plugged my guitar into the amp one day only to get no sound from the guitar. The amp is working - I plugged a different guitar in and it worked - but the guitar seems unresponsive.
If the guitar is active and the battery is dead you will not get any sound. If the output jack or some of the controlls have been twisted and may have broken the connections on the inside.
When i plug it in the lights come on, respond to me pushing buttons, but the sound isn't going through. i tried inputting both a microphone and an electric guitar, and i tried outputting to both a...
Make sure you have the input and output cables to the correct side. The power should come on when you plug in the INPUT cable from teh guitar. A mic MAY have insufficient output to drive this. You may need to use a guitar that has a preamp built in.
Bussing sound comes out the tube,even when it it connected correctly
Make sure you have the correct power adapter, not a substitute. Make sure your guitar is outputing enough... You LIKELY will need a guitar that has a preamp in the guitar, (not a passive pickup guitar). This device is nothing more than a small amp that drives a speaker which the sound travels up the hose. If your guitar creates a buzzing noise, then this device will do that too... Plug a set of headphones directely into your guitar to verify the sound is clean... NOTE, only one side of headphone will have guitar in it if the headphones are stereo type.
The active light does not light up when I plug my guitar in and no sound comes out from the talkbox ... But the guitar sound can run through it to an amp where the guitar sound comes out
It sounds like you have NOT connected the power adapter to the box to power it. The guitar sound won't be too loud as you run the hose to your mouth and pick up the sound with a microphone such as a Shure SM57 which then goes to your amplifier. Without the power adapter the internal amplifier will not produce any output.
1helpful
I bought my Taylor acoustic/electric brand new. It sounds great, but when i plug it into my amp no sound comes out. I replaced the battery, but it still failed to work. When i plug it in to the amp and...
IF YOUR GUITAR has a built in tuner, make sure the tuner is off as it disables output while tuning... The other thing is to check if you have a volume control on the guitar that might be set too low.. Make sure if you are using 1/4 inch plug guitar cable that it is NOT a TRS balanced cable, as that will turn off the power in the guitar.
3helpful
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
