Question about Eastern Tools & Equipment ETQ TG72B12 Portable Gas Generator
My TG72B12 runs but does not put out any electricity. I have been told its the stator. Where can I purchase a stator for it. Motor runs great, only has 37 hours on it
No electrical output, no power coming into volatage regulator. Can the stator be rebuilt?
    Top Expert:
  • 6,705 Answers
Did you check the fuses, circuit breakers?
Why starting to replace things, without knowing if it is really defect?
First check all contacts, switches and cables, before doing drastically things.
Posted on Jul 17, 2014
6ya staff
SOURCE:
How to set up governor for Generac GN-220 motor
The circuit board controller is monitoring the engine rpm and frequency and thus controls the frequency, via the governor actuator, or stepper motor as you say. You can't adjust it. I doubt this is the problem it sounds like either engine is not delivering HP, or there is a stator short causing excessive load / current draw bogging the unit down, incorrect wiring of the stator output. Ha someone taken the stator output leads off the breaker? check the stator resistance and shorts to ground.
Feb 16, 2015 | Generac Electrical Supplies
Stator replacement
MY SON HAS A CHINISE BIKE AS WELL. OUR STATOR IS UNDER THE LEFT SIDE UNDER THE PULLEY SO THEY MOST LIKELY TELLING YOU CORRECT
May 06, 2014 | 2008 Dfang DF 1253
Westinghouse Electric Dryer, Drum doesn't turn on start up, if your spin drum and close door it will start,
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 22, 2012 | Westinghouse Laundry Dryer Motor...
My ED56 won't start unless you turn the drum by hand why?
Apr 28, 2012 | Fisher and Paykel Dryers
I have a Hobart Champion 10,000 welder generator. It runs but I am getting no juice out of it. Won't weld or put out power to run anything.
measure ouput on ALL available sockets - anything?
Take cover off electric motor-generator, visually inspect windings.
Measure continuity of all stator windings (2 or 3 points usually)
Measure continuity of stator thru brushset.
If all measures ok - has to be AVR module.
There is no mistery in generator - just stator to induce and rotor to obtain voltage.
Jan 01, 2010 | Hobart Champion 10,000 All-in-One...
Honda 5500 Generator
If you have checked the stator, rotor and brushes and they appear alright then it is probably a voltage regulator. The honda dealer can run a test and confirm the problem at very little expense. It cost me 25 dollars Canadian to preform the test and it was well worth the money because you cannot return electrical parts and they can be very expensive. Have a great day!
davedulmage@sympatico.ca
Aug 13, 2009 | Northstar Generator 20 Hp, 13,000 Watt,...
A-200 Problem?? Apparently the electric wire coming into the back on the machine plugs into a small circuit board, the male prong aparently touched the copper wrap that makes the motor spin and has blown,...
Hi Adam. Easy part first! Check locally for an electric motor specialist, who can rebuild (rewind) the stator for you. If no luck there, check out eBay for a complete motor (stator and rotor), they come along fairly often.
If this solution has assisted you, please rate it. ricardok45
Apr 09, 2009 | Hobart A200 Stand Mixer
Eastern Tools & Equipment ETQ TG72B12 Portable Gas Generator Logo
208 people viewed this question
Top Eastern Tools & Equipment Electrical Supplies Experts
wadingriver
wadingriver
 Generator Guru...
Generator Guru...
Are you an Eastern Tools & Equipment Electrical Supply Expert? Answer questions, earn points and help others
