Bush Visions 32" Flat Panel Corner TV Stand Logo
Felix Gates Posted on Jul 17, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do remove my bush 32 from standby?
It's stuck on standby, you can hear the sound of the programme, but i cnt seem to get the screen to show a picture. The picture dissapered while watching a movie and even now i cnt seem to ge it back.
Level 3:
Top Expert:
  • Bush Master 76,851 Answers
  • Posted on Jul 17, 2014
Bush Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14984646
Points
237762
Back-light problem. Contact any service technician. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box. It will be best to replace the inverter board as card basis.
Bush a642f tv stuck in standby mode suspect power supply capacitors but all seem ok
Hi
Press and hold the menu button on the t.v (not on the remote) for about a min, this should reset the processor to unlock it.
Re: hannspree 32" xv tv, screen comes on with logo then clicks off and still able to hear sound
Hi
It sounds that the main board to your TV have shorted component/s [ICs, Capacitors Etc..] In this case, it will be better to contact any experienced service technician, or, the authorized service center for Hanspree; to get this fault rectified. Actually, the troubleshooting to this problem will be a skilled one, that a normal user can't do.
I think, you got me.
Gopakumar Gopalan Google
Bush 32 inch Tv is stuck on standby and 2 year old has broken the remote control. The tv is set up for child lock so pressing the buttons manually is not helping. Have just purchased a universal remote...
If you unplug the power cord, let it sit for a minute and plug it back in, it should let you turn the tv on by the button at least once. Then you can at least get the remote linked up. Please reply back to your post if this resolved the issue. I would rather you try this first before going further.
Problem with a bush BTV185DVD
The screen off light is stuck on on my Bush TV/Video/DVD combi BTV185DVD. I have tried to turn it to standby but then it just goes back to "Screen off" and nothing happens to the screen. Please help.
1helpful
2answers
Tv lost picture and sound
TRY UNPLUGING SET FROM THE WALL FOR 1 MINUTE. PLUG SET BACK IN AND CHECK. IF PROBLEM PERSISTS TAKE IT TO A QUALFIED SERVICER. UNIT PROBABLY HAS A DEFECTIVE MAIN TOTAL ASSY.
9helpful
2answers
Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
Top Bush Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Bush Office Equipment and Supply Expert? Answer questions, earn points and help others
