SOURCE: Keurig model B50:
Before you go and throw this out or pull it apart, the most probable cause is just that there is not enough water in the unit to allow it to heat. Air gets trapped in them and they need to be bled. At start up Keurig has a procedure for this (read the manual). Unfortunately after startup you can't use this procedure. Unplug the unit. Take the water container off and lean the machine over- even try to tip it upside down. Put the water container back and try it. Repeat several times if needed. If it does start your done. These units were built to have water in them all the time and this shouldn't have to be done again.
SOURCE: Keurig coffee maker is on, lights lit, machine
Even though the light is on, this does not mean the element that heats the water is working. After you fill the machine with COLD water, and the light has been on for a few minutes, unplug the machine and dump the water out into a bowl. Carefully, feel the water. Is it hot? OR just warm? Or still cold? If it is warm, the element is not heating properly. If it is cold, the element is NOT working. If the water is HOT, then perhaps the tube from the water storage reservoir to the brewing basket is clogged. If that tube is clogged, it needs to be removed from the machine and cleaned out. If the element is not working, or heating the eater hot enough, that element needs replacement. Chances are, the replacement cost/cost of repair would be more then a new coffee maker.
SOURCE: My Keurig platinum B70 will not pump water through
Please get a hold of the company at the number in the manual, they will send you a new one if they cannot fix it. Magic words, I got it as a gift three months ago, it worked fine until now. Worked on mine. Sending out a new one today. This company works with you until you are happy. and I am getting 4 boxes of coffee! Free!
SOURCE: my keurig says it is brewing but nothing comes
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
SOURCE: Our platinum keurig has stopped
heatman101
again.
Keurig Coffee
heatman101
heatman101
