What do you put in the clean tub option keeps blinking
Hello Jodi, thank you for your post!
Your Frigidaire washer (FAFS4474LW0) will automatically prompt you to run the CLEAN WASHER cycle typically every 50 cycles. If you wish to begin the cycle, press SELECT when prompted. This maintenance cycle uses hot water and two rinses to remove residue that may cause odor. For best results, I recommend to use the CLEAN WASHER cycle once a month
You may press the CANCEL button to manually perform the cycle at another time if you prefer. You can do this by following these directions:
·Rotate cycle knob to Rinse & Spin
·Then press the CLEAN WASHER option button
·The LCD screen will display "SYSTEM CLEAN"
Hope this helps! - Z
Hello Larry Occhipinti, thank you for your post!
If you are pushing the necessary buttons on your Frigidaire washer to perform a system clean and they are not working, it could be a possible issue within the control panel. I would recommend a reset on your appliance which can be done by disconnecting power from your appliance for roughly ten minutes. If that does not correct the issue, you can run a hot water wash cycle with a cup of bleach inside the tub to clean your appliance out as well. I hope this is helpful. -Matt
