I have the HTC Inspire 4G that was given to me. I need to hook this up to my StraightTalk plan. I added the APN per straighttalk but it still will not work.
Go in to mobile networks
go to apn or access point names
reset to default
after it resets,
ad straight talk apn settings
select it restart phone
should b working if settings r correct.
contact stragitht talk for correct settings
OK first of all go to settings, more, mobile networks, access point names, then press menu, select new APN, type the name of your service provider followed internet e.g MTN INTERNET, type Internet at where the APN is and then press menu again and select save. you are done
SOURCE: MMS settings htc surround. I have Straight Talk
Hello
You need to re-configure your set from the service provider.
Good Luck
SOURCE: I just purchased a new HTC Inspire 4G cell phone
Thanks for visiting FixYa!
Just a note:
HTC Sync cannot be used for file transfers of music and videos.
To do that, you need to remove your phone's memory card - insert it in a PC - download the Music/Videos to the PC - then transfer them to the memory card.
SOURCE: my HTC inspire 4G won't turn on or charge. the
Was going through this article. It might help:
http://community.htc.com/na/htc-forums/android/f/113/p/9281/40043.aspx
SOURCE: I need the apn setting
here you go i have my htc inspire 4g working perfect now it connects to the internet and sends mms fine
APN:epc.tmobile.com
Proxy:216.155.165.050
Prot:8080
Username:none
Password:**** (i typed in 4 stars) :p
Server:* (i typed in 1 star)
MMSC:http://mms.msg.eng.t-mobile.com/mms/wapenc
MMS proxy:261.155.165.050
MMS Port:8080
MMS protocol: Wap 2.0
MCC:310
MNC:260
Authentication:NONE (Make sure you dont leave blank put NONE)
APN type:default,admin,dum,mms
enjoy
SOURCE: i need free unlock codes for htc inspire 4g
You have such a good mobile and don't risk loosing it with trying to unlock using unknown free offers. Most of the free offers available offers are looking to be scam and unreliable with many negative reviews on them. So it is safe to try unlocking through any reliable paid unlocking site. for example you can get the accurate unlock code for your HTC INSPIRE 4G at very low cost from www.Superunlockcodes.com with easy unlocking guide.
Please note that all data will be deleted from the HTC Inspire 4G as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
First, try this:
If that doesn't work, or if your phone is frozen:
All data including third-party applications will be deleted from the HTC Inspire 4G. Once the wipe is complete, the phone will reboot to its factory fresh state.
