I have tried ajusting the potentiometers, but the speed will not slow down at all.
I am not familiar with this brand, but many turn tables adjust the speed using a rubber wheel and a turntable motor with different shaft sizes. The shaft is ground smaller in steps the further from the motor. As the rubber wheel is moved up the shaft, the slower the turn table spins. Most times you can lift the turntable up (may have a clip to hold it in place) and look to see if the wheel moves up and down on the shaft as you shift speeds.
