SOURCE: I need to replace my hall sensor - LG WM0264H
I fixed this myself. I found an on-line LG service manual and bought the hall sensor (about $30). It took all of a half an hour to repair this myself. I read that too much soap and fabric softener will make the circuits on the mother board heat up and short out the hall sensor (gunk and resistance on the wash drum). It is running like a top again. The local parts store said to periodically run bleach and water through the soap, and softener despenser to help keep it clean.
SOURCE: LE Error Code- I replaced the Hall sensor & the problem returned
You need to replace the motor that goes on the hall sensor. We've had the same issue. What kind of soap are you using and are you only using 2 Tablespoons of detergent no matter what the load size? The only reason these usually go bad is becasue your not using HE soap or your using too much soap.
Ours goes bad becasue we can't use any HE detergent becasue my son is highly illergic to all brands of HE. I have no choice but to use regular soap. But we have had to replace the hall sensor twice in 3 years.
SOURCE: LG LE error. WM2277HW Have replaced the Hall Sensor and ran
As long as that Tide HE is not 2x or 3x concentrated, that would be the maximum amount of detergent for a large, heavily soiled load. Lighter soiled and/or smaller loads should be about 1 tablespoon. If 2x concentrate soap, use only half that. The reason this could cause an LE error is that suds between the inner and outer drum will cause excessive drag on the inner tub, with the possible result of an LE error. I'd try to run a load on Sanitary, heavy soil level, with no clothes, and a washer cleaner such as Affresh, Washer Magic, Whirlaway hot tub cleaner, Smellywasher cleaner, or Tide washer cleaner to remove any possible build up of soap residue from the outer tub area.
Sometimes, cycle selection/ loading level/ load type can cause LE errors. Gentle wash cycles, such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because these cycles are more gentle in tumbling and spinning, putting too much in the drum can register an issue with the motor. Remove items, reset unit and test with a Rinse/Spin cycle.
Another possiblility would be a loose electrical connection dealing with the Hall sensor, at the sensor, the control board, or (much more unlikely) the wire connecting them.
On rare occasion, the main control board can be at fault, but generally, replacing the Hall sensor does take care of the problem. (over 90% of the time)
Testimonial: "Right on with the solution...After fully disassembling the washer ohming all the wires checking all connections. It turns out a loose hall sensor."
SOURCE: lg washer wm2277hw le code comes on think it is
Hi
Thanks
for using FixYa. You are right, the 'LE' error message indicates the control
board has detected that the motor is either not turning, or has locked up for
some reason. Monitoring the motor is the job of the Hall Effect sensor board
which constantly determines the direction and speed of the motor and feeds that
information back to the control board. If there is a problem between what the
motor should be doing and what the hall effect sensor says the motor is doing,
the 'LE' will be displayed and the cycle will be stopped. The hall sensor is
rather easy to replace, and is covered by a seven year part warranty (in US).
Take the back cover off. Take the big nut off and remove the motor rotor.
Remove the bolts holding the motor windings. Remove the electric plug on the
sensor and unclip it from the motor winding. Snap new sensor on and
reassemble. Usually takes under a half hour. Please do rate the solution
if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
SOURCE: how can I make the
You can turn the power on, and hit the spin speed button, and then start it. It should drain out.
If your still getting an LE error, and already have replaced the Hall sensor, it's most likely the Stator. If you know your date of purchase, this is most likely still under the 7 or 10 year warranty. Meaning LG pays for the part (over $100.00+),
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed
when either the motor is not working or the control board thinks that the motor
is locked up. A Hall Effect sensor is used in these washers which monitors the
speed and direction of the motor and then forwards this information to the
control board. Hope you understand by now that this LE error is displayed when there
is an issue with the motor or when the Hall Effect sensor sends wrong signal to
the control. Conclusion is you'll have to check both motor and hall sensor and
replace the part# that is bad, usually I have seen the sensor going bad. Please
get back to me if you have any other questions.
Kevin
