My bosch styline digital kettle dose not stop boiling, when it get to around 90 degrees the 80 and 90 degree lights keep going on and off so it keeps boiling
Temperature digits 70 80 90 turns on and off at "random". And boiling does not stop!
I cleaned the round metal rings in the bottom of the kettle.
The two innermost rings are connected to the temperature sensor.
Use some sharp metal or fine sand paper to scratch the top edge (kettle at upside down) of the rings.
Clean/blow away the "metal dust" afterwards, and it should work again
Check for its temperature sensor. Replace it if you found it damaged.
SOURCE: Why does the water boiled in this kettle smell and
hello,
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
thank you and thanks for using fixya.
Testimonial: "Glad to hear it's not my imagination. On complaining to the retailer they suggested that I have a very delicate palate, or do I have fillings in my teeth!!! I do, but my 85 year old mother sure doesn't. Thanks again."
