Tablet will not turn on or charge. Battery is completely drained, please help.
SOURCE: My new Asus memo hd 7 will not turn on whatsoever.
Remove the rear cover...use your fingernails, or something thin and plastic (like a guitar pick) to get it started, then work your way around unsnapping it until it is off. Now unplug the battery, the battery connector pulls up towards you to unplug, it snaps in. Now, you have to put the rear cover back on..because as you will notice there is foil on it, and pins on the board that ground through that foil. After the cover is back on...press and hold the power button for 30 seconds or so to completely discharge the energy from the board. pop the back cover off, plug the battery back in, put the cover back on...and plug the tablet in. Now when you push the power button you should see a battery charging icon...let the tablet charge for an hour or so...then boot it up if you would like, but let it charge to 100% before unplugging. Good luck!!
SOURCE: THE TABLET BATTERY DRAINED DEAD NOW IT WONT POWER
Have the power adaptor checked by an electrician, most probably you will need a replacement.
If you establish that the adaptor is working, then something happened to the battery charging circuitry in your Asus and it will need repair.
If it's still under warranty, then you are good, otherwise it would be better if the adaptor alone failed, as replacement adaptors are rather inexpensive compared to laptop repairs.
Testimonial: "thankyou"
