I am no expert on the matter but I know a great company that offer on-site free estimates that might help you.
I'll leave you all the info that I got from them below, they have more than 20 years of experience and are really professional. Also offer 24/7 services which is great if you have an emergercy! They specialize in: ·Basement waterproofing Toronto ·Basement waterproofing ·Wet basement ·Leaky basement Underpinning basement
almost all modern metal detectors are waterproof, since many people who enjoy this hobby do so on the beach. it depends on the coil inside, some are simply waterproof, and some are completely submersible
Possible water damage to head light relay in the fuse box under the seat or the stator which controls the head light relay. Get a auto electrician to do an trace check on the wiring & connections to rule out all other faults. If the lights cut out after an heavy bump and come back on after a set time, the fault could be the relay or stator. Have the auto electrician resolder the relay connections in the fuse box (about 40 connections), also have an 12v LED warning light fitted to the stator connections with enough wiring so the LED can be mounted on the handle bar. If the LED cuts out the stator is at fault(very costly), if the LED stays on the head light relay is at fault. Also better waterproof the standard fuse box , the case is not that waterproofed (easy done with insulation tape). Hope this helps.
I just received this error message on my Miele W 1712 (Waterproof Fault). Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message. 1. Turn off the machine 2. Unplug it 3. Open the drain outlet and take out the plug. 4. Dry all the visible water with a cotton cloth. 5. Tilt the machine FORWARD and hold it until you see water gushing from underneath the machine. 6. Repeat this until you see no more water. 7. Plug the machine back inn. 8 VOILA no error message! I hope in your case :)
For our model Alemnesh's suggestions were spot-on. It's hard to believe that a machine with such a good reputation would (a) allow this fault to occur so easily and (b) not have its own manual provide explicit guidance as to how to fix it.
I just received this error message on my Miele WPS 4146 (Waterproof Fault) Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message.
So here is the fix that worked for me.
