LG 42PC1DA 42 in. Plasma HDTV Logo
Posted on Jun 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a vertical green line on the right side of our screen. We can get rid of it by moving the picture over but then it is off center.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1697
Points
Any verticle bar which is blue, red green about an inch wide can be fixed by replacing a control board in the set. Board number 6871QCH038C. Can be ordered through Parts Store.com for about 112.00....easy to install yourself, located behind two larger boards which are ribboned together. Takes about an hour.
Anonymous
Level 2:
  • Expert 197 Answers
  • Posted on Jul 01, 2009
Anonymous
Expert
Level 2:
Answers
197
Questions
0
Helped
91204
Points
366
Try a dvd player and see if it is there bad paneh if it goes away bad cable or satallite box
Why do i have a green line on my tv
Vertical green lines on tv screen - Samsung 60" LED TV ... - iFixit
https://www.ifixit.com > Answers > View > Vertical+gre...
Jul 5, 2018 · 6 answers
Unplug all cables except the power cable, turn it on and see if you still have the green line. If without any image input, the line is there ...
How remove colored vertical lines all over screen of my LED ...
Dec 9, 2015
I have horizontal lines on part of my TV screen. - Sony Television
Dec 18, 2017
SOLVED: Why there's a green line - Samsung Television - iFixit
Aug 6, 2016
F-Series Vertical Green Line - Samsung Television - iFixit
Mar 8, 2018
More results from www.ifixit.com
Why does my TV have green lines on the screen? - Quora
https://www.quora.com > Why-does-my-TV-have-gree...
Sept 17, 2016 - With the green always on, it suggests that the cable the connects to the panel may have a bad line. Whether or not the cable has moved a bit to cause a short ...
6 answers · 10 votes: If its the same on every channel it means your TV is broke. I'm not tying to be a wise guy ...
There is a very thin green line going down my TV screen ...
Jan 3, 2021
How can I repair a TV with vertical lines on the ...
Dec 21, 2016
What causes a horizontal line on a flat screen TV? - Quora
Jul 25, 2018
What does it mean if a Samsung TV starts displaying ...
Jan 29, 2016
More results from www.quora.com
How to Get Rid of a Thin Green Line on an LCD - ItStillWorks
https://itstillworks.com > rid-thin-green-line-lcd-36231
A line of solid color indicates stuck pixels within your LCD. ... Your LCD produces specific colors and images by altering the colors of the thousands of tiny ...
5 tips to get rid of stripes on your TV screen - Coolblue
https://www.coolblue.be > advice > tips-for-removing-li...
Dec 18, 2021 - You can read 5 tips on removing horizontal or vertical lines on your TV screen here.
Vertical green line on Samsung LED TV : r/hometheater - Reddit
https://www.reddit.com > hometheater > comments > ve...
Apr 18, 2016 - It is most likely dead pixels within the monitor itself. You can try a stuck pixel video on YouTube that will flash colors or even give you a ...
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Tv fell off stand. tv has vertical rainbow lines on right side of screen. how do I get rid of the lines?
Color patches due to strong shock or vibration cannot be eliminated by anyway, to CRT type TVs. Gopakumar Gopalan Google
How do I get rid of green line?
your problem is a faulty T CON BOARD.
Part number TCON BOARD 6870C-0060F
hope 2 help
www.bostonrecycling.net
Coloured lines on screen
Make sure first that the picture is centered by using the remote control to move the picture vertically and horizontally. Use the round pad towards the center of the remote and push the button according to which direction you want the frame to move.
24helpful
4answers
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
23helpful
5answers
Green line on TV with DVD playing
The aspect ratio is fine, I just fixed mine you have to use the TV remote, and press the left or right directional button depending on where the green line. Philips TV offsets the picture when using HDMI, but its easily fixable using this remedy. Time to take the tape off haha!
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
