Galaxy s3 i9300
Hi you can easily unlock your samsung galaxy s3 mobile by using unlock code. If you need unlock code you can visit this site Theunlockspot.com here you can get the code and unlock your mobile easily. To get the code you have to mentioned which country is locked now,network provider and imei number. Then they send unlock code through email
Theunlockspot.com
Use the code u already entered when constructing the lock
SOURCE: samsung galaxy android unlock..cannot unlock my
Hi, I have a couple of idea for you to try.
1) Log in to your google account on your pc, the same account you registered for your phone
2) After logging in look at the top right corner of your inbox/email page, it would say your google username. Like say if you name is John, and you have a google id thats registered to your galaxy s as , [email protected]. Now this google id on the top right corner of the page would be displayed as [email protected]
3) Type in the google id, thats visible on the right hand top corner of your page (like [email protected]) into your galaxy s handset locked page, and type in the password.
TADA AND YOUR ON TO THE NEW SCREEN TELLING YOU TO PUT IN ANOTHER PATTERN.
or theres this one:
Take out the battery, the sim card, and the SD card leave the phone for 2 to 3 hours like that.. Put everything back in and boot up the phone.. This should work.
You could try this instead of waiting 3 hours, just remove battery and press power on switch for 20 seconds but this may not work.
or if you've tried everything, the only other way would be to take it to a Samsung mobile phone shop.
or do a factory reset:
THIS WILL ERASE ALL YOUR DATA THOUGH
Go into recovery mode - vol up & home & power. Once in the menu, select factory reset.It may take you a couple of attempts to get to the recovery mode but it does work, just keep trying.
Regards
Mike
SOURCE: how to brighten the screen during internet usage with galaxy s3
While in browser, open settings (bottom left button) and change display setting. The s3 has separate display settings for browser and general phone. Hope this helps.
SOURCE: My Samsung Galaxy S3 Showing Downloading Do not turn off target !! What I had to do?
yes you can remove batt.
SOURCE: How do I set voicemail ringtone for Samsumg Galaxy S3
Click on phone icon, click menu > call settings > scroll down to voicemail settings select ringtone select the ringtone you want click OK
SOURCE: sim network unlock pin for samsung galaxy s3
I dont think thats the problem, it was in the tablet, I took it out and when I tried to reinstall it I cant figure out if its in right ot not,
