Hello, I don't remember my pin code for the phone and now I need the puk code to open it. I have lost the puk code for the phone. Could you help me with this?
PUK lock (Personal Unlocking Key). It's a security feature on most mobile devices that protects your SIM card data and unique for SIM card. May I suggest that you contact your sim network provider as they are the only one who can provide you the PUK codes. Once you done the PUK unlocking you can use the unlock code.
Get the network unlock code
https://www.unlockninja.com/unlock-nokia+phone
SOURCE: hello.. i forgot my nokia 1600 and 1200 security code..
hello..i forgot my nokia 1200 phone secuirty code..
hope you will help me for the code
SOURCE: My pin code is blocked. Need Puk code. Pls help
The PUK code is a code associated with the SIM card and not with the phone.
You have only two ways to get rid of the PUK code. Either you replace
the SIM card , or you call phone provider that issued the sim cadr (eg.
At&T, Virgin, Tmobile , Vodafone, Telecom etc.)
PUK means "personal unlocking key" .
The PUK code is asked if you enter a wrong pin 3 times.
You need to call the phone company that released the SIM card, they can retrieve the PUK code from a database for free.
In your case you need to contact your SIM card provider technical support to unlock the SIM.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone will not ask for the PUK anymore.
SOURCE: I need code puk nokia 2720 plisss!!!
To get a PUK code you need to call your Mobile service provider. They will provide you the PUK code for creating another PIN.
Note: there is no other way to get a PUK.
Thank you for choosing Fixya
SOURCE: nokia xpressmusic pin blocked enter puk code
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider cangive it nobody else in this world nor any software.
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
SOURCE: nokia e71x pin code blocked , enter puk code
Every PUK code is unique so nobody can tell you your PUK number, but i will tell you what you can do!
1) If you still have your packet that your Sim Card came in, you should find your PUK number in there, if you don't have the packet, please read bellow.
2) You must get a phone that is on the same network as your phone and call the networks Customer Care and ask them for your PUK number, they will ask you for your phone number, then they will tell you your PUK number. Once you have done this, you will be able to reset your Pin number so you will be able to go into your phone again.
Thank you for using FixYa!
Rate this solution
