Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill Logo
A
Anonymous Posted on Jul 20, 2014
Usb charger from a makita battery - Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill
goalken highlight
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Mar 10, 2020
goalken highlight
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
4630
Points
54
Your feedback helps me a lot, A very meaningful event, I hope everything will go well <a rel='nofollow' href="https://run3sonline.com/">run 3</a>
4 Related Answers
A
Anonymous
  • Posted on May 23, 2008
SOURCE: makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Anonymous
  • 625 Answers
  • Posted on Aug 21, 2008
SOURCE: Makita LXT 18V will not charge
looks to me like a defective batterie
A
Anonymous
  • Posted on Oct 04, 2008
SOURCE: re: makita 18v lithium-ion batteries can
of course
Anonymous
  • Posted on Oct 11, 2011
SOURCE: on the charger flashes red
Your battery is shot. $75 - $100 for a new one.
2answers
How can I reset chip on my Makita lithium ion 18v battery
Based on experience I can tell you that it is is generally the temperature/cutoff/individual cell monitoring sensor in charger that dont allow the batteries to take a charge. Once the same condition is detected 3 times by the same charger it considers the batteries to be bad and refuses to accept it. I have 2 batteries that wont charge on one charger but works perfectly fine when i charge it on my other Makita charger so basically there is no problem with my batteries.
I would suggest first you check the voltage of your drained battery by a test multimeter. For 18volt battery if it is close to 18volts 1-2 volts less is just fine! Then there is no issue with your battery. Makita chargers are very expensive hitech which is useless in my opinion the lipo chargers (used in rc hobby) example skyrc are better quality cheaper and does a better job and you can easily charge your makita battery with it as well but this is only recommended if you decide not to go with Makita charger any more. Some basic information about multi chargers for Li-ion battery to follow the safety is make sure you use the right connectors with correct polarity. For 18v volts max voltage should not exceed more than 20.50 and the allowable charge current is 2.7amps also ensuring that batteries dont heatup.
10helpful
How do i convert a makita charger model DC18RC at 110 volt to 240 volts?
The DC18RC are most likely to charged the BL1830 battery, which is the most popular of 18V Makita power tools. It is a Li-ion battery.
And the DC18RC battery charger has two volt 110 Volt and 240 Volt.
The 240 Volt DC18RC charger can replace model DC18RA & DC18SD because of its improved performance and full compatibility with Makita's NEW 'Star' labelled batteries that communicate between the tool, battery & charger. And, it is a fast charger.
It can charge a Makita BL1830 Battery in approx 22 minutes.
But, I do not recommend to convert a makita charger model DC18RC at 110 volt to 240 volts.
The reason is as below:
1. This will void product warranty ! If you follow this mod, you do it on your own risk !
2. There are several comments that described
same model # but with different design and components.
Please beware that this mod might not work on your charger
or worst, will damage it.
Only perform this mod if you know your way around with electronics !
2answers
Makita battery
Check that you have the correct battery in the charger as the charger will not charge any type of battery, only the battery type listed on the panel.
4answers
How to fix bl1830 battery when flashing red to green in charger
Take the liberty to disturb:
Our company is a Shenzhen battery factory, engaged in battery industry for 14 years, in 2010 began to set foot in the tool battery pack accessories industry, the MAKITA 18VBL1830 14.4V BL1430 opening 10.8V BL1013 series battery pack, Bosch 12V lithium battery pack and charger.Milwaukee 12V M12 1.5A 3.0A M12 M18 charger etc..Manufacturers supply quantity of large amount of pricewelcome to 86+15014034610 QQ 47018380 Mr. Miao
2answers
Hi, I have repaired 3 Makita 18V 3Ah Li-Ion batteries recently by removing good cells from other faulty batteries. The Voltages are good now on all 3 and they charge/discharge OK on my own charger but...
You can get a 18V replacement Makita battery for your drill. The replacement one is cheaper. Replacement MAKITA BL1830 battery pack 100% compatible with the original BL1830 battery, high quality, wholesale price.
http://www.drillbattery.com.au/buybattery.php/makita_BL1830_power+tool+battery.html
17helpful
3answers
MAKITA LXT BL1830 18V LITHIUM-ION 3.0AH BATTERY
If the charge count on the batteries is under 300, Makita will replace them. Makita has a known defect in this battery that causes the battery to shut down before it is dead. So as of now they are exchanging ones with low use.
If they are truly defective and makita won't replace, you have to open them, find the dead cell or blown fuse, and replace. Search youtube makita battery for a video on repairing this battery. But once the red and green lights on the charger flash, the the battery can't be charged on a Makita charger -- it's been locked. So use a third party charger.
3answers
Makita Battery Charger DC18 RA
Maybe your battery is died, you can replace it on
http://www.drillbattery.com.au/buybattery.php/makita_1220_power+tool+battery.html
Jan 20, 2009 • Hand Tools
Top Makita Drills Experts
Sean Wright
Sean Wright
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Makita Drill Expert? Answer questions, earn points and help others
