Need the code list for the urc3021 remote control for an lg flat screen tv.
2968,2974,2939,2985. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: need tv code list for urc-4605
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC4605
just right click and save as on the download links.
if this does not work you can try the search method,
you do
this by either holding down the device button eg: TV or if you have one
the "magic" button for three seconds, a light should then flash twice
to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For low price replacement remotes visit www.sparky-uk.com)
SOURCE: Help! lost device code list for COMMTEL CONTROL FREAK REMOTE CONT
codes for grundig , 0331,1211,1221,1231,1241,1251,1261,1271,1281,1301,1311,1321,1331,1341,1351,2541,2551,
2751,2781,2791
hope this helps .
SOURCE: I have a LG TV & need code for one for all remote URC3021B00
LG started out as Goldstar, merged with Lucky Corp., to become Lucky Goldstar, LG ;-)
Although your remote doesn't list any codes for LG, one of the Goldstar codes may work.
Try 0030, 0056, 0178.
If that doesn't work you may have to try the "Search for Code" feature by first turning your TV on, then follow these steps:
1.On the remote control, press TV once
2.Press and hold SET until the LED (red light) blinks twice,
then release SET.
3.Enter 9 - 9 - 1.The LED will blink twice.
4.Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5.To lock in the code, press and release SET.The LED will
blink twice.
The URC-3021 is a 2004 basic model without any learning capability, if you are unable to find a code, it may be time to buy a new remote.
There are newer, low cost universal remotes available at Walmart, Target, K-mart, and other retailers, that should have a more up-to-date code list.
Hope this helps, Greg
SOURCE: I have a Access 4 One for All remote control but i
i NEED THE CODES FOR THE ACCESS ONE FOR ALL REMOTE MODEL # URC-4700B00 FOR A ORION VCR THANK YOU VERY MUCH IF YOU CAN HELP.
