I have a phillips remote but can only control on/off and volume, not menu or any other modes. on tv i can bring up menu on its buttons but can't get any response than just the page,no more control. help!please
SOURCE: phillips magnavox big screen
That is the service menu code. I forgot the code but you can search it on this sit jou will find it. But be cearfull jou can damage your set.
SOURCE: Phillips Magnavox model 9p5034 c101
You can get the actual remote control for that model at the following link. If your not sure which one it is just leave them a email with your model number and they will respond quickly. Heres the link.
http://servicemanuals.vstore.ca/
SOURCE: Menu Button Does not Bring up the Menu
I f it does not work with the remote or the set check and see if it is stuck if it still does not come up the problem is the small signal baord 313503711711.
SOURCE: 32 flat screen problem with remote and menu
Sounds like you need to get a Green Setup remote but if you are using this privately you will not be able to obtain one to program the tv. They are only available to hotels since the tv's are for commercial use.
