Sound only on video games no sound on TV
Check its audio settings with TV signal. Refer its user manual for details. If the color system have been changed, there will be no audio too. Set it with proper system, ie, PA:, SECAM, NTSC etc:-
SOURCE: toshiba regza 42" lcd sound but no video
Holding the power button down for 10 seconds fixed this problem on my Regza 47"
SOURCE: No Video for my cable tv. Audio works
You have the TV connected to the cable box with an HDMI cable, I'll bet. The problem is with the cable box. If you unplug the cable box and plug it back it it will reboot and proabably work. You should connect the cable box to the TV using component cables and you won't have this problem again.
SOURCE: no sound
i have the same problem, and i was just watching tv the one day i bought it, and now there is no sound just picture, all the connections are good. and i dont use a stereo or any surround station. please help!
SOURCE: I want to connect my Toshiba Satellite A305-S6863 Laptop to TV
You have to configure yout laptop to output through the s-video (which does not carry sound, so you need to either use the laptop speakers for sound, or the line output (headphone jack) to the TV).
I don't know if all toshibas are the same, but with mine, if I hold Fn (near the windows key) and press F5, it will change the output, do it a few times until you see a picture on the TV, some settings make this your extended desktop, meaning you can drag a window from one screen to another.
Testimonial: "Very helpful and well stated information! Thank you."
SOURCE: Toshiba Regza 40XV645U garbled sound
There is an issue with the audio processor. Most likely it is the main board needs to be replaced in order to fix the issue. You will need to remove the back cover in order to get access to it.
There could also be an issue with the power supply supplying the right voltage to the processor. This can be checked by seeing if the 18V DC is present at pins 3 and 4 of CN90 on the power supply. If the voltage is present, then replace the main board. If it is not, replace the power supply.
The location of the connection ports is in keeping with today's standards. They are easily accessible and well constructed.
Port Listing: 4 HDMI, 2 SCARTs, Headphone Jack (with Independent Volume Control), S-Video, Composite Video, Common Interface, Component Video, Digital Audio Out (Optical/Toslink), RF In and D-Sub.
You can read the reviews here:-
http://reviews.cnet.co.uk/tvs/toshiba-regza-32rv635db-review-49302355/
and
Hope this helps, if so do rate the solution.
