If you forget your unlock code: At the Enter Unlock Code prompt, try entering 1234 or the last four digits of your phone number. If that doesn't work, press - and enter your 6-digit security code instead.
NOTE: Your phone's 4-digit unlock code is originally set to 1234. The 6-digit security code is originally set to 000000.
Your phone’s 4-digit unlock code is originally set to 1234, and the 6-digit security code is originally set to 000000. If you had not changed these codes before locking it, try these..
Your phone’s four-digit lock/unlock code is originally set to 1234. The six-digit security code is originally set to 000000.
If you forget your unlock code: At the Enter Unlock Code prompt, try entering 1234 or the last four digits of your phone number. If that doesn’t work, press and enter your six-digit security code instead. .
Lock code (5 digits) can be used to lock the phone to avoid unauthorised use. The factory
setting for the lock code is 12345. To avoid unauthorised use of your phone, change the
lock code. Keep the new code secret and in a safe place separate from your phone.
This I had Tken from Nokia Manual.So the Lock Code is 12345. But by mistake u might have changed the code. SO contact your nearest service center.They may help You
You can lock your phone manually or set the phone to lock automatically whenever you turn it off. To use a locked phone, you must enter the unlock code. A locked phone still rings or vibrates for incoming calls or messages, but you must unlock it to answer. You can make emergency calls on your phone even when it is locked (see page 68). Locking Your Phone Manually
Find the Feature > Settings > Security > Phone Lock > Lock Now
Unlocking Your Phone Tip: Your phone’s unlock code is originally set to 1234. Your service provider may reset the unlock code to the last 4 digits of your phone number.
Setting Your Phone to Lock Automatically You can set your phone to lock every time you turn it off:
Find the Feature M> Settings > Security > Phone Lock > Automatic Lock > On
If You Forget a Code, PIN, or Password Note: Your phone’s 4-digit unlock code is originally set to 1234, and the 6-digit security code is originally set to 000000. Your service provider may reset the unlock code to the last 4 digits of your phone number before you receive your phone. Press To 1 keypad keys enter your unlock code 2 OK (+) unlock your phone Find the Feature > Settings > Security > Phone Lock
Master Clear Clear all user settings and entries except SIM card information, erase all downloaded pictures and sound files, reset all options except unlock code, security code, and lifetime timer: M > Settings > Initial Setup > Master Clear Caution: Master clear erases all user-entered information (including phonebook and datebook entries) and user-downloaded content (including photos and sounds) stored in your phone’s memory. After you erase the information, you cannot recover it.
