How to unlock the code of my original phone settings.
SOURCE: how to unlock a Nokia 6630?
Give this a try?
http://www.symbian-freeware.com/download-unlockme-1-0.html
SOURCE: nokia n95 8gb
Hi if your phone is asking for securtiy code when you switch it on then i can give you the master code to reset the securtiy code to what it was when new but if you can acess the phone and just forgot your security code and want to change it to do this you will need a flash lead and unlocking software if as i said the phone is asking for scurity code when you switch it on then if you give me your imei number its on back of phone under battery and looks like 123456/12/1234567.
it should be 15 numbers long give me this code then i can get you the master code ok let me know and i can assist you further ok
SOURCE: 6630 phone lock code
Please give me your phone's imei no.
it is written on the back of your phone after removing battery,
then i will give you your security code.
SOURCE: my nokia E51 is locked can u tell a master code to unlock
First of all try 12345 (the standard one)
If this is not working try using this software: NSS to read the phone code:
http://www.b-phreaks.co.uk/software.htm
You should see the lock code when you use the softare.
If not, you might consider formatting your phone.
Switch it off, and : Pressing the following key at the same time: 3 * green button, switch it back on - the three keys must be pressed and held - then press the power button still holding the 3 keys.
The best places to find out what to do:
http://www.allaboutsymbian.com/
http://www.symbian-freak.com/
SOURCE: How do i unlock my nokia 6630? If possible without
HI If you are asking for pin contact your service provider , he will give you a default pin . If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider(VODAFONE) which is specific for each and every mobile number . Donot try PUK code many times or else your sim will be blocked and you will need a new sim.
Contact your sim customer care(VODAFONE) department over phone. Its free of cost to get the pin or puk no.
