I have connected my dvi adapter from pc to hdmi input on my lcd tv and everything is fine until i press av on my remote and try to switch back i lose the pc connection.any ideas
There is an adapter that goes from HDMI to DVI, There is even a cord that is HDMI on one end and DVI on the other.
A lot of TVs have the VGA PC connection on the back, not sure if your model has it, but you need DVI specifically and its not as common on TVs.
Analogue TV reception has nothing to do with signals from Blu-ray players.
Connect your Blu-ray player to either a HDMI port on the TV, or use a HDMI to DVI adapter (which is picture only) and supplement it with a a connection for audio via RCA/phono- or RCA/phono to jack cable from the BD player to the TV.
Press the AV Input button on the remote to cycle through the input sockets.
There should not be a driver required for this. As long as your HP desktop has a VGA video or HDMI video output, you can connect to the back panel of the TV from the video port of the PC. Then, on the remote, select the "PC" option for VGA input, or HDMI for the HDMI 1 or 2 input(s). If the PC only has DVI output, then it is important to know if the output is analog or digital. If it is digital (DVI-D or DVI-DD] then there is no available port on the TV to support it. Using a DVI-VGA adapter on a DVI digital output will not work as there must be a digital-to-analog conversion in order to work.
For lg hdtv the method to hold the magic button for a while until led for tv is on and pressing code 991.then power off button and ch+ button for 35 times untill your tv switches off and back on several times and back ch- button.This works well for hdmi cable connection as well as to set the magic remote to work with guide and AV button properly.Then input for hdmi works well.many thanks.
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
your output cable is in the back of your t.v. there is a color designated on its hole then you have to buy a a cable in any electronic shop like components cable or hdmi cable try to read the back panel of your tv
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug. Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV). I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
the DVI input must be HDCP compatible in order for HDMI to work. It's a DRM encryption protocol. Condolences. Blame hollywood for it. The monitor model is too old to have had HDCP support built in to the DVI input.
