Question about Car Audio & Video
I got my legacy 10 inch 4 ohm svc in today and it dont have the + or - marked on it anywere, and I cand find a site that showes it anywere. Can anybody help me?
    New Friend:
  • 32 Answers
Are you on about a sub? If so can be wired in reverse polarity and all that happens is sub reacts in opposite to normal.just connect the way sounds best.you will not damage sub
Posted on Jul 22, 2014
4 Suggested Answers
6ya staff
SOURCE:
Bronson Erceg
  • 53 Answers
SOURCE: i have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
Hi mate very nice amp you got there here is the specs for it
Model: MA Audio HK401SX
Hard Kore Series 1800 Watt 1 Channel High Performance Class X Car Amplifier
1 x 1800W RMS @ 0.5 Ohm Mono
1 x 1200W RMS @ 1 Ohm Mono
1 x 650W RMS @ 2 Ohm Mono
1 x 500W RMS @ 4 Ohm Mono
Fully Unregulated MOSFET Power Supply
2 Ohm Stable @ Mono
1 Ohm Stable @ Mono
0.5 Ohm Stable @ Mono
if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
Posted on Oct 19, 2009
Bronson Erceg
  • 53 Answers
SOURCE: 2 alpine type r 15's 4 ohm dvc and 2 american bass
Option 1 (parallel) = 0.5 ohm load
Voice coils wired in parallel
Recommended Amplifier: Stable at 1/2 ohm mono This set up will blow your mind as your amp will put out 1800rms at 0.5 ohm
Casey Reed
  • 4 Answers
SOURCE: Hi ,how can i connect my two 10 inch JBL double
It is confusing with the 4 channels it gives you but you really only need to connect it to one or the other positive and negative terminals. The amps channel setup looks like this + - + - . You can connect to the first positive and negative, the second, or combine them. I had mine installed by a professional which is how I know. Also if you want to run your amp at 2 ohms then connect the subs voice coils in a parallel circuit which means that all positives are connected to each other and the same goes for the negatives. it should match the impedances of both sub and amp. Hope this helps!
Posted on Jul 16, 2012
Hohow do you wire a 10 inch kicker l5 320 X 221 B
Would need to know its ohms if its a SVC OR DVC and amp being used.
Oct 12, 2014 | Car Audio & Video
Can my la590 American legacy 2 series 800 watt handle Boss CX122 Chaos Exxtreme 12-Inch Subwoofer 4-Ohm Voice Coils??
It is only stable to 4 ohm mono(which is 400 watts RMS or a bit less not the max rating of 800 watts which is a PMPO rating).
Your Sub would have to be wired in series(8 ohm final load, if you wire it in parallel 2 ohm-you will fry that amp).
Jan 07, 2014 | Car Audio & Video
I have a 500 watt vpower amp and i wanna hook two 10 inch subs up to it the only problem is these subs r not ones to screw with they r 1 ohm and legit have caution written on the side of the subs....so wud...
are these subz dvc or svc subz. and dont be afraid of the one ohm your amp will do what it needs if you bridge it to mono. Or your subz are actually drivers,if so 500 watts will just get laughed at by those speakers
May 15, 2011 | Car Audio & Video
What way should I hook 2 12" jl audio to a jl audio 1000/1
Is this sub an svc or a dvc? From what I looked up they are svc, so each sub's voicecoil is 3 OHMS, connecting them in parallel would lower them to 1.5, and your amp is capable of going down to 1.5 ohms. So I would suggest running them in parallel.
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_4ohm_svc_2ohm.gif
(Although from the information I gathered these subs have 3 OHM voicecoils, so in the diagram where is says 4 OHM it should say 3 OHM, and the 2 OHM should say 1.5 OHMS.
This is a good site to help calculate OHMS: http://www.bcae1.com/spkrmlti.htm
Hope this helps.
Nov 11, 2010 | Jl Audio 12W7 Car Subwoofer
I need to wire two w 7 svc ten inch subs to a 1 ohm load
jl didnt make w7 svc but i will include a wiring schematic from jl for the w7......http://mobile.jlaudio.com/support_pages.php?page_id=145
Aug 26, 2010 | Jl Audio 12W3 Car Subwoofer
Can i have box dimentions for my 12" xplod sub
  • Warranty Terms - Parts 1 year limited
  • Warranty Terms - Labor 1 year limited
  • Product Height 12"
  • Product Width 12"
  • Product Weight 7.8 lbs.
  • Product Depth 6-1/2"
  • Subwoofer Size 12"
  • Resistance (Ohms) 4 ohms
  • Bottom Mount Depth (inches) 10"
  • Woofer Composition Mica-reinforced woven glass fiber composite
  • Woofer Surround Rubber
  • Peak Power handling 1300W
  • RMS Power Range (Watts) 380
  • Cutout Diameter or Length (inches) 12"
  • Sensitivity 84dB
  • Frequency Response 30Hz - 1kHz
  • found at:::---- http://www.bestbuy.com/site/Sony+-+Xplod+12%22+Single-Voice-Coil+4-Ohm+Subwoofer/9202481.p?id=1218057724056&skuId=9202481
Jun 04, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
I need to replace the fuse box with the relay and i dont find it anywere do you know were i cand find it??
Remove driver side kick panel cover just above the pedals. You need to disconnect the battery when you do any work regarding main wiring. Have your radio code with you in case it defaults to safe mode when you reconect the power.
May 20, 2010 | 2001 Volkswagen Cabrio
After 4 minutes the sound on my Sharp 32 inch LCD TV goes off, but picture stays on
Sounds like a software problem, I would locate a local svc co. for an estimate first. Some mfg have web sites that svc co's can download updated software to take care of strange problems that may occur.
Mar 04, 2009 | Sharp Televison & Video
Ohm load???
You can't wire a pair of single voice coil 2ohm subs to achieve a 2 ohm mono load. Too bad you don't have 2 four ohm SVC's. Sorry
Jun 19, 2008 | Jl Audio 12W3 Car Subwoofer
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
