Please help the button that takes the pictures on my camera has stopped working
SOURCE: Panasonic Lumix DMC-tz1
lens mechanism needs cleaning ( moisture ) and possible alignment ( jarred ) ; charge or replace batteries , before getting estimate ;
SOURCE: Problems with my Panasonic Lumix Digital camera
let me explain to you guys, these cameras are slim line cameras and if dropped or mishandled it is going to give problems. you cant blame the camera if you are not handling it corectly.
SOURCE: Purple Screen
If it is only 2 months old,then you still have warranty.
A purple lcd, viewfinder and photo is a 100% CCD failure.
If out of warranty, not worth the repair.
SOURCE: My panasonic lumix fz28 gives me an error saying
This error is for the optical image stabilisation.
Generally the camera should be ok after your turn it on and off again. The error you are getting is because either the OIS has malfunctioned or is stuck.
I think you might need to take it to Panasonic since the camera is still new and you are sure that you did not bang it or dropped it.
But Before that, I suggest that you take out its memory stick, the battery etc and keep the camera like that for about 15 minutes. Then only reinsert the battery (fully Charged) and try to power on.
Try a little tap ( but not too hard) on the side of the camera....this might realign if the OIS has got misaligned. If you are lucky, you might not need to go to Panasonic.
SOURCE: Panasonic Lumix Fx35 Malfunctioning
Go into the setup menu and scroll to "reset"...follow the on-screen instructions. This procedure might work. If you can't get into the menu because of malfunctioning buttons, try a manual reset...remove the card and battery...press all the buttons...insert the card first and then the battery...turn it on.
