TV has been un plugged for some time and when you plug it in the orange light flashes but will not turn on
SOURCE: Vizio Turning on problem
UNFORTUNATELY THE ANSWER IS NOT , THAT PROBLEM DEFINITELY NEED PARTS TO BE REPLACED. PROBABLY POWER SUPPLY
YOUR RATING TO MY ANSWER ITS HIGHLY APPRECIATE
THANKS
SOURCE: won't power on
Your power board has gone out. If your tv is under warrenty then you can get it done for no cost. Vizio will send power board and main board and Tv tech will come on-site to install the parts.
SOURCE: Whenever my T.V. is plugged in the Vizio symbol
Although your problem had somewhat different behavior, it still points to a failure of the main power supply, chronic in too many later sets.
The supply is normally built on a separate board
since these are often out-sourced by set manufacturers.
Unplug your set overnight to allow potentially
hazardous voltages to discharge, remove the back panel of the set so you can
see the guts.
Look for a smaller board with larger parts on
it; some cylindrical (capacitors), others block-like and relatively large
(chokes and transformers).
You should also see a relationship between the
board and the incoming AC.
Check the board for a label or if not present, a
stamped-on number.
Call the manufacturer's service center with your
TV model number and the number found on that board and inquire about
repair/replacement costs; if both are offered, they won't be that much
different.
If you must buy a new board, don't dispose of
the failed one as there are smaller companies that can repair it for less than
the mfr. and then keep it as a spare as this problem will likely arise again.
SOURCE: plugged in orange light turno on vizio light is white no picture
possibly is the main board.
SOURCE: My Vizio 42" LCD SV421XVT
U getting a non respones from ur remote or the manual side panel tv controls buttons wright.U already tries resetting it back to factory setting.But the problems still the same.Yes,the tv Tuner signal board is the causes and the problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by
meg_car on Jul 08, 2009
Service by: mjsazon
