Need help for reseting the c6000 error on kyocera printer.
SOURCE: Have error: C6000 on Kyocera
Have Kyocera FS-1118MFPF that is coming up with Error C6000. Can we fix this ourselves
SOURCE: Error C6000 is showing, can you tell me if I can fix myself or call for service.
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
SOURCE: Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
SOURCE: how do you reset a C6000 error on a Kyocera Mita
it is a error on your heater unit. it sometimes comes with power fluctuation. you need to enter service mode, it is a dangerous place to be if you do not know about copiers and their settings and i advice you to rather get a trained tech to do it for you.
to reset this error, do the following, but please take care and DON'T fiddle around.
type in 10871087
the machine will display U000 and be in maint. mode
type in 163 (this is the code to reset the error)
press ok/print
on some models it ask for "execute", select it if neede
the machine will now restart and be ok
** if however the machine restart and the error occure again, there is a deeper problem that need to be attended by a trained tech
