Kenmore electric smooth top convectional self-cleaning range. The clock has disappeared and when I unplugged the stove so 12:00 would flash, I put in the correct time and pressed start as the manual said to do,, the screen went dark again,,, I've only had this stove since February 21, 2014
SOURCE: Kenmore Select Clean Self-Cleaning Electric Range Model 6659580
This means you hace a problem with your clock. Take the back off the stove and then pull the ribbon connector off the clock and clean the terminals. If that doesnt fix it replacing the clock should fix it.
SOURCE: Can I replace the glass stove top on my Kenmore Range????
Yes! check at repairclinic.com you can find parts for your appliance. be sure to have your model number handy.
SOURCE: Got F40 error code self-cleaning my 790.9642 Kenmore range
try this, after several calls I finally found out what the code meant. code meant. Power supply issues, not necessarily with your power supply but with the appliance itself. Of course they want to send a technician for $65.00, which may be worth the headache. All someone told me was to turn off the power braker for 2 hours and try again. Yeah right, after 2 hours of heating your house and paying the electric bill, but when breaker is off there will not be any electric used. code f40,
SOURCE: Kenmore Electric Range model 790 has F9 & F1 code error
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
