Works fine with no clothes in it
SOURCE: My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
SOURCE: maytag bravos washer that sounds like airplane
u need to replace the tub. includes the bearings
SOURCE: My maytag clothes washer Bravo quiet series 300,
What does the Sd code mean? This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds. Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations. Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing? This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent. Is "Sd" displayed and the wash cycle dial is not flashing? If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds. Is the drain hose kinked or clogged? Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work: NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
SOURCE: when my Maytag bravos washer
Cause: suds. The wrong detergent or the wrong amount of detergent, makes the motor overheat.
Why? In my opinion when suds are detected the program needs to make them go away for fear the clothes won't be clean. So the program makes the motor do extra work to try and fix the problem. The poor washer motor gets worked to death because the water ain't right. This washer is designed to work with a small amount of water. Only a tiny amount of soap is needed to do the job. Put a cup of detergent in there and the machine is gonna constantly run way past time to be done just to get rid of the detergent. This causes the machine to overwork the motor and destroy the rotor position sensor.
SOURCE: I have a brand new
I had this one come up on a washer I had professionally installed for a client. When I looked into it I found there were shipping blocks made of squeaky Styrofoam the installers left in place. Only made the noise when it was full of water and working hard shifting back and forth in agitation. It said right in installation instructions to take the shipping blocks out too.
