SOURCE: Web password
You probably have a network card called a IB-30 installed. You will need to reset this card by changing the jumper from is original position to the next one. This will restore the original factory settings, there are only one jumper on the card. If you still have the CD your IB-30 came with it will explain to you under troubleshooting how to restore the factory defaults.
SOURCE: Kyocera laser printer toner refill
refill...uh oh probably wouldnt try it..there's is like only 1 company that does kyocera refill toners.....call KATUN... you can try to find that on the internet..you most likely willl have to buy actuall kyocera toner..
SOURCE: Kyocera FS-4000DN Laser Printer call for service
that's just a toner motor error..most likely the toner was not put in properly..remove the toner than reseat the toner making sure it snaps secure into place..you should than be fixed
SOURCE: I HAVE A KYOCERA FS-4000DN PRINTER THAT SHOWS ON
Call the Kyocera hotline they have technicians you can speak with over the phone who can help you.
You may contact Kyocera Technical Support Monday - Friday 9 am - 6 pm EST at:
1-800-255-6482
SOURCE: Kyocera FS-4000DN is showing install
> without buying a Maintenance Kit ?
Either you buy the kit, or you sell the printer "as is" on eBay, after buying a new printer.
