Hi Tradeboyle,
Please search 'Sony Bravia KDL-40S4100 40 in five blinks' on google and you will get several videos containing the solution of your problem.
Good luck.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating, to many popular brand TVs and other devices.Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Gopakumar Gopalan Google
1 blink abnormal AU Power Voltage 2 blink abnormal d5v/a9v power voltage 3 blink Abnormal panel voltage 4 blink backlight failure 5 blink abnormal main power voltage 6 blink abnormal speaker voltage 7 blink internal temp. rise 8 times ic5000
