Try ShopJimmy.com - they have a huge stock of TV parts. They are used but tested meaning they are usually much cheaper option and often have parts that are no longer available.
Power board: (verify correct part before ordering)
http://www.shopjimmy.com/polaroid-860-az0-mlt666amh-power-supply.htm
Picture of above part:
http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sj860az0mlt666amh.jpg
List of available parts for your TV:
http://www.shopjimmy.com/catalogsearch/result/index/?q=element+2611&stock=all
You should verify the part number from your original board before ordering and also visually check that the replacement part matches your original. The part number is usually on a barcode sticker on the board or printed on the board itself. Be careful here as the number on the board may be the
board number so try the find a part number if possible - the same board can be used for various configurations of components so is not a guarantee of being the correct part. Also manufacturers sometimes use different boards in televisions with the same model number according to price/availabilty/reliability.
You can also verify stock, part number, etc by contacting the supplier first. They may also be able to help you if you can't find your part on their website.
http://www.shopjimmy.com/contacts
Alternatively, once you have identified the part number, search for other suppliers by entering the part number into Google or Google Product Search. Be sure to enter the part number with any hyphens, spaces or periods as it is written on the board and if you have no success, also try the same search without any punctuation, e.g just the numbers and letters with no spaces.
http://www.google.com/products
Hope this helps.
Regards,
BElectric
