Tv does not come on with remote
SOURCE: can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
SOURCE: westinghouse LCD power light but wont turn on
G'Day!
Unfortunately, what you're describing is a repair
issue. You won't be able to address the problem with troubleshooting.
There is a part inside the TV that needs to be replaced. Since you're not under
warranty the cost will likely be a minimum of $200 parts and labor.
However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
SOURCE: westinghouse model tx-47f430s lcd tv wil not turn on
This is known as SLEEP MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These step is done to over-ride the sleep mode.
Roan
SOURCE: westinghouse 42 inch lcd flat screen tv
only get sound from my 42 lcd screen fro westinghouse, no display
SOURCE: Westinghouse TX-47F430S 47 in. LCD TV TV won't
Hello, it sounds like your power supply is gone, there are two things you can do to fix this problem. One is to attempt a component repair on your own, this just means you have to open the unit and look at the power supply. Normally the thing that will go out first on this unit are the capacitors. You might get lucky and find one that is puffy or fat, if you do you will need to get the value of the capacitor and simply put it on google so you can find a replacement. The number two thing you can do is simply send a quick email to [email protected] with the request for the power board and they will let you know the price and availability of the board, you will than have to do a simple swap of the boards and your TV will be back up and running in no time. Please rate my help on this site.
