Question about Kenmore 94702 Front Load Stacked Washer / Dryer
Sour smell coming from washer even when door is
A sour unpleasant smell coming from the washer even when door is left open. Washer is used frequently.
If you have a front loader it will hold water around the seal of the door and after time it will mold and start to smell.
Posted on Jun 30, 2009
6ya staff
SOURCE:
I cleaned my washer with affresh and it still smells very sour
dump a box a baking soda in it and run empty . see if it helps your problem
Jun 22, 2016 | Whirlpool WTW6400SW Cabrio Washer
Sour odor. Even though I take my clothes out right away.
The problem is that water sets in a filter area below the tub and sours, or smells like raw sewage. This is common on most front loaders, Whirlpool makes special tablets used in washer to take out the odor.
Jul 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Sour smell inside washing machine
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Jul 11, 2009 | GE WHRE5260E Top Load Washer
I have a Kenmore Front loader Model c45192. when not in use it smells very wet and unpleasant
Hello Friend, Your problem is simple to resolve. This is a common issue. It is possible that the water quality being delivered to the washer could contain higher than normal amounts of micro-organisms causing the growth of mold and mildew. Basically what is happening with your washer, when not in use the washer door remains closed trapping in moisture which is the perfect invironment for mold and mildew to grow. You should run a large empty load with bleach and from now on just leave the washer door partially open when not in use. This should resolve your problem. Happy to help, Tim.
Jun 27, 2009 | Washing Machines
Sour clothes smell from washer
Until you can find the filter (I'll investiate!) I suggest running it on hot hottest wash you can (empty) with just bleach. That at least should kill the bacteria that are causing the smell
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenwood elite washer is spurting water 3 to 4 times during the agitate cycle. i do not know how to take it apart. it does not leak water at any other time.
The smell in my Kenwood Elite washer is horrible. I use bleach, I use the new TIde Washing Machine Cleaner, I have tried the hot cycles, I have left it open between washings but can't leave it open very much because we have a door out to garage that would hit the washer door if left open too wide. I can't leave clothes in there too long or they smell too much and have to rewash. The clothes never come out of washer smelling super clean. After I dry them using a scented dryer sheet, they are acceptable, but I never have really clean smelling scented clothes any more.
Apr 26, 2009 | Kenmore Washing Machines
KENMORE ELITE HE3 WASHER
2 things you may try if you haven't already ..let washer fill with hot water ..pause and open door pour in about 2 cups chlorine bleach before starting back up..with rag soaked in bleach/water clean inside front door boot ..be sure to roll boot toward front and clean out accumilation under it wash as much as possible off door seal..allow to finish cycle (normal wash should be fine)..may also try removing lower panel remove pump acess plug and clean pump out thoroughly..you are not alone ALL front washer have same issue and if some sort of routine cleaning isn't done problem reoccurs also leaving door slightly open between usues will help ..by the way that is a german made washer
Sep 12, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire Affinity Front Load Washer
You have to remove and clean the rubber around the front of door,
, Snap it back on.
disconnect AC to prevent any accidental shock.
open the bottom access panel
screws on bottom front , open the large filter and be ready for latent water to spill out , have rags ready.
clean the inside of the filter with clorox.
finally run a strong solution of clorox when you finish.
then rinse well.
leave the door open after loads finish
the door has a child lock
black dot next to lock on door , insert coin and rotate.
keeps them from closing the door.
Feb 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Problems with Rubber Door Sill
I had a service person come out this week and he told me to leave the door open or get a top loader. I am returning it. The smell is horrible.
Oct 01, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Kenmore 94702 Front Load Stacked Washer / Dryer Logo
296 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
