Have change water switch
SOURCE: Tub fills with water......that's it.
This is probably a bad timer motor.
Two screws on right/left of head, flip head back. You will see a small motor on the timer that operates when the timer is set. If this isn't running, then you need to replace that or the entire timer. Probably easier to change just the motor.
Best luck in your repair
Joe
SOURCE: How do I change the water level pressure switch on
I believe you can remove the screws on top control unit should be 1 on each side then flip back control unit ,remove the hose ,connectors,pressure swith, i had a problem with mine and found out that the hose had fallen off quick fix!
SOURCE: My kenmore 24642300 fills with water, thats it
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24642300&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
Two possibilities:
I think you've started in the right direction.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the washer still doesn't work, check the motor coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
SOURCE: Is there a way to bypass the water level switch on Kenmore HE5t
No - it is vacuum operated. Just replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: water level switch won't turn
HELLO THERE AND WELCOME TO FIXYA:
tHERE ARE A FEW THINGS THAT YOU WILL WANT TO FIRST ENSURE
FIRST ENSURE THAT THE WATER IS ACTUALLY TURNING OFF AT THE INLET VALVES ON THE MACHINE IF THESE VALVES LEAK THE WATER WILL CONTINUE TO ENTER THE MACHINE AFTER IT IS FILING THIS IS THE MOST COMMON PROBLEM ON THESE
HOWEVER IF YOU HAVE ALREADY PINPOINTED THE WATER LEVEL SWITCH AS BEING FAULTY THEN YOU CAN REPLACE IT HERE IS WHAT IT LOOKS LIKE IN THE IMAGE BELOW BE ADVISED THAT THEPART MAY BE A LITTLE BIT DIFFERENT THAN THE ACTUAL ONE ON YOUR UNIT SO I WILL POST A FEW OF THEM
TO REMOVE THE PART YOU WILL NEED TO REMOVE THE COVER ON THE CONTROLE PANEL AND IT SHOULD EXPOSE THE TUBE THAT GOES FROM THE CONTROLE PANEL TO THE TUB WHERE THE PART IS
