SOURCE: command codes
Read page 23 in the manual.
Press "enter" & the #1 keys together for 5 seconds.
Then press stop.
Press "system menu" & change the option back to dvd3.
Then press "enter" & the #3 keys together for 5 seconds.
Press "system menu".
Or call Sony Main Support # 1-800-488-7669
SOURCE: Command mode change disabled remote
According to Sony, if you turn the power on and hold the Enter key and the #1 key down together for at least 3 seconds, everything will default back to factory settings.
Mike
SOURCE: Accidentally reset from DVD3 to DVD1...Now nothing
Press & hold the Enter button. Then press & hold the number 1 for a few seconds. Release both. Now, press the System Menu button. You should have access to the system menu.
SOURCE: COMMAND MODE SETTING HAS BEN CHANGED FROM DVD3 TO
press enter and 1 or enter and 3 hold for 5 sec should match whatever unit set to
SOURCE: set up sony RDR-VX535 recorder to DVD1. now remote does not work.
See the manual on page 22.
The solution is to reset your remote code to DVD1 (default is DVD3).
Press the ENTER button and NUMBER ONE button simultaneously for at least three seconds. Viola, control returns.
