Question about Sennheiser HDR 120 Consumer Headphones
Why are my sennheiser HDR 120 wireless headphones not transmitting any sound
Why are my headphones not transmitting any sound? The headphones are charged and plugged into the TV. I am not sure if I have them plugged into the right place. Also On the charger stand there is a channel switch that has 3 positions: right, middle and left, I am not sure which position it should be in. Lastly there is a tuning dial below the volume dial-do I have to use that to get sound?
    Sergeant:
  • 399 Answers
You plug the charger base in the AUDIO OUT of the TV, not the headphones. You wear the headphones. You use the volume dial to lower or increase the volume. And don't forget to plug the base in a power outlet and turn on the headphones.
Posted on Jan 11, 2015
6ya staff
SOURCE:
Anonymous
  • 9 Answers
SOURCE: Bad battery for my Sennheiser HDR 45 headphone
A replacement battery can be purchased from Sennheiser for $20.00.
Battery is: BA 151
Sennheiser Link:
http://www.sennheiserusa.com/newsite/productdetail.asp?transid=004146
Posted on Jan 15, 2009
Anonymous
  • 9 Answers
SOURCE: Bad battery
Battery Part Number: BA 151
Sennheiser Link:
Anonymous
SOURCE: Sennheiser Wireless Headphone Stops transmitting signal
I had the same problem when I plugged it into a new HDTV. The problem was that the sound on the TV was set too low. The transmitter has a feature that automatically turns off when the signal is off or too low. Try turning up the TV volume to a high/higher level and it should solve your problem. Using the headphone jack with the white input allows you to use the headphones while bypassing the TV speakers.
Posted on May 02, 2009
Anonymous
SOURCE: sennheiser hdr 120 headphones no longer hold a
Twist the pad counterclockwise on the left earpice. You'll find the batteries underneath.
Posted on Mar 06, 2010
caroldon
  • 17130 Answers
SOURCE: The left headphone of my
First of all if the right side is working the wireless is working alright and the fault is in the processing section, the left audio preamplifier , the left side power amplifier and the left side earpiece.
So you might have to test with a audio signal to confirm from the preamplifier, the low-power amplifier driver for the earpiece and the earpiece.
Once this is confirmed the focus can be the wireless section, possible fault in the receiving section.
The use a a multimeter to check and knowledge of electronic circuits is necessary to check around this section. Please check and respond.
The advice/tip given is with the belief that you are competent. You must attempt to do it yourself only if you are technically/logically able, especially when dealing with delicate devices, damaging while trying to open, Probing electrical/electronic circuits with high voltage or delicate components. Since the advice given by me is with the inputs provided and not based on a visual inspection, there can be further reviews required in some cases.
Posted on Oct 09, 2010
Are there batteries in the headphone unit ?
Yes, there has to be or they wouldn't be able to receive the signal from the audio source.
Feb 19, 2015 | Sennheiser HDR 120 Wireless Headphone
Sennheiser 120 green light goes off
Can you remove the rechargible batteries ? To try and reset them ? Or maybe replace them ? It sounds like the batteries have gone bad and not charging
Nov 12, 2017 | Sennheiser HDR 120 Consumer Headphones
Sennheiser hdr 160 will not pick up the signal from the receiver
assuming the battery is charged, have you tried to switch to a different frequency band, etc.?
check page 28 of the user manual for possible actions when there is no sound in the headphone.
Oct 12, 2011 | Sennheiser HDR 160 Wireless Headphones
How do I charge batteries?
The headphones will automatically charge wirelessly when placed in the cradle that should have come with the package. To make sure the headphones are placed correctly, a red light should illuminate letting you know they are being charged and are properly placed.
May 03, 2011 | Sennheiser HDR 120 Consumer Headphones
Sennheiser hdr 120 headphones no longer hold a charge. where are the batteries in the headset?
Dec 27, 2009 | Sennheiser HDR 120 Consumer Headphones
Crackling noise
it might be the speaker or it break
Jul 29, 2008 | Sennheiser HDR 120 Consumer Headphones
Sennheiser HDR 120 Consumer Headphones Logo
469 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Geoff
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
