Error code 13497-92815 just started to happen. Will not allow me to start the program. What does this mean?
Software malfunction is normal and the same can be solved as quickly as possible, but this is only possible if you try to sort it out using the best solution possible. We provide the solution facilities that will lead the software to its most precise working point for all queries and problems linked to QuickBooks error code 6150. The functioning mistake may occur for various reasons that need to be understood in order to find the perfect solution to the problem. It is essential to follow the correct strategy for discovering the solution, and this is achieved only when specialist services provide technical help.
According to Intuit, QuickBooks error code 6150, -1006, "When a company file is produced, opened or used, an error code will be presented."
The following causes lead to the error message being displayed:
solutions for the QuickBooks error code 6150:
Using the above steps, the mistake is not resolved many times. To solve the problem, try the other techniques.
Method 1: Restore from Backup
One of the above measures should work to fix the QuickBooks error code 6150; however, if the issue persists after step-checking, the next best option is to restore the Company File from backup. Follow the measures below to restore Backup Company File:
Drawbacks of Backup restore:
Some of error are not know but easily handled by Intuit QuickBooks technicians so for more help contact http://support.quickbooks.intuit.com/support/ and if need guidance while any problem follow Intuit Tech Support .
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor .
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water .
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
