HP Photosmart D110A Multifunction Printer CN731AB1H Logo
j
joe hodges Posted on Jul 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CN731A D110a photosmart AIOscanner nor working properly?
Printing works fine scanner does a scan when I run test "from pc" but never never indicates any info /image on the pc
teamtech
Level 2:
  • HP Expert 108 Answers
  • Posted on Feb 17, 2018
teamtech
HP Expert
Level 2:
Answers
108
Questions
0
Helped
322491
Points
547
Https://goo.gl/HCdPe8
try to remove the old driver
reinstall the latest driver
if the problem remains then it will be a scanner failure error
Karl Whisenand
Level 3:
Genius:
  • Master 1,554 Answers
  • Posted on Jul 26, 2014
Karl Whisenand
Master
Level 3:
Genius:
Answers
1554
Questions
Helped
752900
Points
4266
Open a pic . hit file print , what happend
5 Related Answers
Anonymous
  • 2985 Answers
  • Posted on Jun 14, 2007
SOURCE: No picture image when scanning
This looks like a CCD failure. Can the image be corrected in the PC software Which image editor are you using?
Filmluvr
  • Posted on Jan 07, 2008
SOURCE: Hard to explain...
I just purchased one of these scanners secondhand, and I have the same problem. You're seeing the underside of the lid where the film strip conveyors and other mechanicals are located. The previous owner (original purchaser) had a piece of white printer paper taped to the underside of the lid in order to prevent this effect. I'm really baffled as to why HP didn't install an insert for users who don't scan photographic prints and film strips.
Anonymous
  • 62 Answers
  • Posted on Jan 26, 2010
SOURCE: My HP 5370C scanner no longer works
The problem is in the connection cable, Check the cable that connects your scanner with your computer, If still not working, try replacing it with a new one.
Anonymous
  • 53 Answers
  • Posted on May 11, 2010
SOURCE: My HP photosmart C4380 series is not scanning. I
The scanner works with two different files running in the background HPQTRA08.exe and HPQSTE08.exe .
If one of the file is not running you will not be able to scan from solution centre.
So follow the documents i am sending you. I am sure you will be able to scan soon.
For windows Vista:-
For USB follow this link:-
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01927438&tmp_track_link=ot_recdoc/c01611159/en_us/c01927438/loc:2&lc=en&dlc=en&cc=us&lang=en&product=3418705
For windows XP:-
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01927078&tmp_track_link=ot_recdoc/c01611159/en_us/c01927078/loc:4&lc=en&dlc=en&cc=us&lang=en&product=3418705
Let me know if any one of these links help you.
Anonymous
  • 374 Answers
  • Posted on Jun 25, 2011
SOURCE: Hi I need the service
The old model scanner came with an old ISA SCSI plug-in card. Even if you had the card, it will not fit into ANY of the card slots on today's motherboards. That card could inly be inserted into a a motherboad from the pre-pentium days - like a motherboard with a 80286 processor. If you ae using a diffrent SCSI controller card I doubt if it will work with this old scaner. FYI, service manuals do not contain schematic diagams and would not cotain the info you need to get that scanner to work with a different scci controller. Sorry, but the 4p is just too old.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Cannot print emails from hp photosmart d110a printer
I'm not certain what is causing this, but an easy solution you might try for working around this problem would be to select all the text that you actually want to print, copy it, and then paste that text into Word Pad or another word processing program available on your computer. If you have been able to print other documents from Word Pad or another word processing program without problems then this would be a quick and easy solution that will do what you want until HP resolves the problem.
1helpful
How do I scan multiple pages to one pdf file from my hp photosmart d110 printer
The scanner is for scanning 1 page at the time and save to a pdf file. To combine multiple pdfs into a single pdf requires user to use a program like Acrobat. There is a free app "PDFBinder" for Windows user as describe by Rob Lightner on CNET. Follow below link for download and instruction.
http://howto.cnet.com/8301-11310_39-57344712-285/how-to-combine-multiple-pdfs-into-one-document/
One more try. My C7280 printer makes terrible noises when it pulls the paper through for printing. I have tried reinserting the back part where I clear paper jams, but it does not help. Also this...
Without hearing the noise or having a description other than "horrible", I'd say probably the pickup clutch or the gears that turn it are having an issue and need to be replaced.
To my knowledge you can't order either of these parts (it's not like the good old days) but at least it's replacement is on sale at the moment for $79.99 from HP.COM (probably what you'd have to pay to get yours fixed at a shop).
the D110A is the least expensive photosmart all in one at the moment.
Keep your 7280 as a scanner though if the ADF (auto document feeder) is important to you when scanning, the D110A is flatbed only.
1helpful
2answers
I have just bought a HP Photosmart plus B210 printer. I have installed it ok and it is wireless connected. everything seems ok for printing but when I try to scan to Paint shop Pro 7 or from Word 2003 it...
Hello Carol,
The first thing you want to do is check to make sure the scanner driver is installed properly and working.
If you are running Windows XP or Vista; go to Start Menu \ Control Panel \ Scanners and Cameras
NOTE: For Vista user you must select "classic view" in control panel to see scanners an cameras.
For Windows 7; go to your Start Menu, in the "search programs and files" section (found below "all programs") type in "scan". You will see a result for View Scanners and Cameras.
Now you should see the HP scanner here. If it is not here then you need to reinstall because the scanner was not installed properly. If the scanner is here, right click on it and select Properties. (For Windows 7 you do not have to right click, you will see Properties at the bottom of the window).
In the properties select "test scanner". If this test fails, the driver is not working and you should uninstall and reinstall the HP.
If this test works then the driver is properly installed. HP should have provided you with some sort of scanning software, try scanning using that. You can also try scanning using Windows Fax and scan (for windows 7), Windows Photo Gallery (Windows Vista) or the Windows Scan wizard (Windows XP).
Thanks,
Pat
2helpful
2answers
"incompatible cartridges"
Usually if you leave the printer off for sometime the ink get dry on the heads or some ink may leake to the sensores so take the cartrage out clean it and clean the heads with cotton swaps...see if the help and let me know
2helpful
2answers
USB NOT CONNECTED ERROR WHEN IT IS CONNECTED
This is a HP hardware/software error and HP has not fixed it.
The C4250 may report that "USB is not connected" but the printer works just fine and when you use the Microsoft Scanner and Camera Wizard to carry out a scan, it works just fine too. So the error message is wrong.
The Microsost Scanner and Camera Wizard can be found on the Control Panel.
1helpful
Printer not communicating with computer
Try go to system prefs, print and fax. Remove your printer from list then add it again. It may pay to uninstall software first, then reinstall
Scan to computer not working
Google, enter "HP Photosmart C5180 All-in-One" and you can reinstall the scanner into computer...free.  Under the black apple in the upper corner of screen find "recent Items" and you will find the Photosmart Studio where the scanner icon is used to scan and create a file in thecomputer.
2answers
Printer not printing properly
When you changed the cartridges, the printer automatically prits a test / calibration page. This page must be placed in the scanner, then you have to press the "scan" key (the green one). It will calibrate an align the system. Then you'll be able to print.
k24674
Grand Canyon Tech
Grand Canyon Tech
