Status light remains on the tv and it shuts off every few minutes
SOURCE: mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
SOURCE: mitsubishi WD-65731
Here is a link to what models have a recall for a faulty sensor... extended warranty on that part preplaceable for free by MDEA.
http://www.mitsubishi-tv.com/j/i/18312/Warranties.html?mid=125121
SOURCE: Mitsubishi WD-62628 power shuts off!
I have the same issue have not done the repair yet but here is a link to photos of the various boards and the problem caps:
http://www.fixya.com/support/t155026-
flickering_blue_picture
SOURCE: will not turn on
check to make sure that you didnt break the kill switches on both filter and lamp door. if one is broken you can just solder the wores together or put as jumper on it somehow.
SOURCE: RED LAMP LIGHT!!
Check to make sure your lamp is not blown.
Make sure you installed a Mits original, and not a generic.
Make sure the lamp is seated and secured properly, as slight movement can cause a loss of connection.
Slide your set out to the side and peer into it through the slats. Can you see the lamp fire on?
Your symptom does not indicate that it could be a problem other than the lamp and the installation thereof, however---there is an instance where 2 capacitors will blow on the power supply and cause a red lamp light to show. Furthermore, the light engine itself could be causing the problems.
But, since you just installed the lamp, I would look over your installation.
